How do you guys remove smaller rocks from your land?
   / How do you guys remove smaller rocks from your land? #21
If you are picking up rocks by hand, I recommend one of these.
Get the ones with the rubber cups.
I use mine for brush also.
   / How do you guys remove smaller rocks from your land? #22
. . . I actually found a 3 pt Chain harrow that I like. Just don't know the price.
That's an ABI 3-point rake. Here's a link:
3 Point Chain Harrows ::ABI Attachments::
I priced them and the price was higher than a Tractor Supply drag-type chain harrow (of course), but I wasn't shocked or offended by the price compared to a plain old drag-type.
I don't have the pricing info any more and can't remember what it was or what size I priced. But I seem to recall that it wasn't much more than buying a drag-type and a boom pole and doing some southern engineering to make a half-azzed lift-type out of it.
   / How do you guys remove smaller rocks from your land? #23
-------------------------------- I actually found a 3 pt Chain harrow that I like. Just don't know the price.
Will it move rocks or just go over them?
   / How do you guys remove smaller rocks from your land? #24
   / How do you guys remove smaller rocks from your land? #25
I suspect it will move them a few feet at best and then go over them. I wasn't recommending that chain harrow for rock removal. I was just identifying the one someone mentioned with a pic.
   / How do you guys remove smaller rocks from your land? #26
Here you go Rockhound - RockHound Landscape Rake
My landscape contractor used a Rockhound to clear rocks and make a seed bed for planting grass and shrubs on our 5 acre lawn. He used the one which attaches to a skid steer and it worked great. He rented it from a local rental business. I've yet to find a rock in the lawn. Note there is also a model with 3PH attach.
   / How do you guys remove smaller rocks from your land? #27
I have seen items shown on TBN that are towed behind, dig into the ground and separate the rocks from the dirt. It looks like it would require a lot of HP to pull it though. From photos it appears that the machine is pulled 6-12" deep and the rocks are separated from the dirt on a moving chain link system that deposits the rocks in a back bucket that is then hydraulically dumped.
I have no personal experience with one, although if it was available in my area, I would certainly rent one if it was reasonably priced.
I don't see this as an item to buy, but maybe rent one if locally available.
Tater Digger! sounds like the old Tater Diggers we had when I was a kid.
Kinda like this...
302 Found
   / How do you guys remove smaller rocks from your land? #28
I get some rocks on my land, I push my pallet forks under, grapple them and pull them out of the ground,
Then load them on my wagon,
and move them out of my fields,
SR
   / How do you guys remove smaller rocks from your land? #29
SR
And then what??
   / How do you guys remove smaller rocks from your land? #30
When the neighbor kids where young I'd set a coke can on my other neighbors fence post and tell them I'd give them a nickel for every time they knocked the can off with a rock. They'd be out there throwing rocks from my property onto my neighbor's all day and it would usually cost less than a dollar ;)
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55314)
PENDING SELLER...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A53421)
2007 Godwin Pumps...
12" PIN ON BUCKET (A52707)
12" PIN ON BUCKET...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
Pull-Behind 66in Smooth Drum Ballast Roller (A51691)
Pull-Behind 66in...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
