How do you guys remove smaller rocks from your land?
   / How do you guys remove smaller rocks from your land? #1
gogo
So CA
L3200HST
Hey everyone,
So I've been really getting a lot of use out of my L3200. I love it. I have done a lot of work on my 5 acres. I used my RCR1860 and mowed all my land. Now I want to get all those smaller rocks sifted out. Does anyone have a tool they have built or bought to gather up the loose rocks on your property? I would love to see what you TBNers have come up with.
Thanks
   / How do you guys remove smaller rocks from your land? #2
Around here they use a "rock bucket".Just tines on the back and bottom;use to sift the dirt our.Kind of a lost cause around here.The frost just pushes up more in the spring.
   / How do you guys remove smaller rocks from your land? #3
If I was buying one, it would be this one with round tines: Bradco 66" Skid Steer, Skidsteer, Rock Bucket, 3" Tine Spacing Universal Skid Steer Quick Attach
It would be even better with the grapple: Bradco Grapple Attachment for Bradco Skid Steer, Skidsteer, Rock Buckets
   / How do you guys remove smaller rocks from your land? #4
Most of my rocks are basket ball sized or bigger. I go around with the tractor & my manual, hand operated shovel and dig them out & fling them into the bucket.
I plowed/disked a small area - about an acre - where the larger mature rocks breed and I get a new crop of smaller ones each spring. I hand pick this area each year with the hope that some day there will be no mo' small rocks and I can plant there. I could probably use something like what xfaxman is showing in his post above.
But, its so darn much fun hand picking that new crop each spring. The fact is - the rocks will never quit, I will get too old to do this each spring or I will just eventually give up, ha ha. The valley where these are being dumped is filling up also.
Thanks guys. I was hoping someone uses something that is pulled from behind the tractor or PTO attached. Any input is appreciated. Thanks
   / How do you guys remove smaller rocks from your land? #6
Usually, if you make the item worth something... then there will be none of them just laying around... Law of Nature #523
   / How do you guys remove smaller rocks from your land? #7
I have seen items shown on TBN that are towed behind, dig into the ground and separate the rocks from the dirt. It looks like it would require a lot of HP to pull it though. From photos it appears that the machine is pulled 6-12" deep and the rocks are separated from the dirt on a moving chain link system that deposits the rocks in a back bucket that is then hydraulically dumped.
I have no personal experience with one, although if it was available in my area, I would certainly rent one if it was reasonably priced.
I don't see this as an item to buy, but maybe rent one if locally available.
XFaxman, Thanks for the link. I see a lot of landscape rakes. Im thinking I might put the rippers down on my box blade, rip everything. then use a landscape rake? It isn't a lot of rocks but I'm sure when I rip it that will change. I'm not going to rip too deep. I just want the bumpy areas to be smoother like most of the land. Anything that keeps me on the tractor all day will be good.
E32 R2- Series Bobcat Mini Excavator (A54865)
E32 R2- Series...
Killbros 260 Seed Conveyor (A57024)
Killbros 260 Seed...
1111-A (A54756)
1111-A (A54756)
2013 WESTERN STAR  4900 SB (A55745)
2013 WESTERN STAR...
INOP/NON - RUNNING 1997 Procraft Fish/Ski Boat (A54865)
INOP/NON - RUNNING...
