1/2 throttle?
/ 1/2 throttle? #1
Gateway 5600
Bobcat 5600
One of our operators keeps running our 5600 at half throttle. Will this foul the turbo?
/ 1/2 throttle? #2
What RPM is "half throttle"? Personally, I run my equipment at whatever rpm needed to get the job done without "LUGGING" the engine. (usually 1700 to 2200)Turbo fouling is usually a result of underloading the engine, or excess idling.
/ 1/2 throttle?
I don't know the RPM's, but can tell it is not at full power.
/ 1/2 throttle? #4
Half throttle doing what?
Our 5610 Series F idles at just over 1200, and I think max is 2800, so half is 2000.
I told my wife to run 1800rpm, Hi-Flow with the 7' brush hog. It has plenty of reserve power to go up small hills when mowing.
/ 1/2 throttle? #5
Same here on any machine I run.
/ 1/2 throttle? #6
Same here. It's very rare that I run any machine at "rated" rpm. I've never had any issues with turbos sooting up. Somewhere around half throttle seems to be my sweet spot.
/ 1/2 throttle? #8
A diesel engine is built to run WOT 24/7 . I have started backhoes , excavators at -0 and as soon as they catch rev them up . Get them hot and quit ******* around with all this (HOW MANY RPM ) QUESTIONS . A diesel engine runs on heat , combustion , not a ******* sparkplug . I have cranked these engines in the middle of the night ,0 below and never had an issue . I see 20 ? Aday about this warming up thing . It is not going to warm up until you work it . DONE .
/ 1/2 throttle? #9
Are you recommending immediately going full throttle on a cold started engine in 0 degree temps?
2014 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR1EH765285 (A61165)
2014 International...
Amada M-3060 Mechanical Metal Shear (Japan) (A59213)
Amada M-3060...
2000 TEREX 60TON T560 REAR WHEEL DRIVE CRANE TRUCK (A59906)
2000 TEREX 60TON...
2018 VOLVO DD25B DOUBLE DRUM ROLLER (A62129)
2018 VOLVO DD25B...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56858)
2016 AutoHauler...
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A55745)
2012 BRUMLEY...
