5010 Gear Cab
/ 5010 Gear Cab #1
NC419N
Gold Member
Kubota BX2670 Kioti NX5510C Ford 3000 ford 4500TLB Ford 9N Farmtrac 555DTC New Holland 1720 New Holland 2120 Kubota BX22 Kubota ZD1200
Its getting close.
What's the good bad and or ugly on a 5010 Gear Cab?
The final choices are it a 1742 Massey and NX4510 Gear cab.
I am so skeptic of the tier 4 engines and realize the time is short on tier 3 units out there. I figure this will be the last "new" tractor that I will be buying so the choice in important.
/ 5010 Gear Cab #2
The bad is also a good....it has a short wheelbase for a tractor with such a powerful loader. That makes it turn tight, but also makes the backend light with a load as the fulcrum point is further rearward giving the loader lots of leverage to lift the back of the tractor. So put Rim Guard in the tires and/or put some weight on the back when using the loader. The other issue is the transmission choice, it is a simple gears trans. Not as handy as an HST, yet pretty bulletproof. Tier III is good. Some of the early production 5010 gear cabs did not warm up well in cold weather, but that was solved some time back by some changes in the thermostat bypass system. All in all, a good machine and priced very well.
What part of the country are you in?
/ 5010 Gear Cab
North Carolina foothills
/ 5010 Gear Cab #4
Well then, I better not try to sell you the last 5010 gear cab I have in stock, it would be a long drive across the USA, even with the cab and AC and the stereo playing!
/ 5010 Gear Cab #5
Tint the windows and fill the R4 tires. Other than that youll love it
2022 EZ-GO ELITE...
2022 CATERPILLAR 289D3 SKID STEER (A64279)
2022 CATERPILLAR...
UNUSED WOLVERINE HYD BRUSH CUTTER (A64281)
UNUSED WOLVERINE...
2015 Kubota RTVX1100C (A62177)
2015 Kubota...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
Caterpillar Specification Manuals Vol. 3 Books 1 and 2 (A63117)
Caterpillar...
