Plasma Questions
/ Plasma Questions #41
You didn't say what day it was but have a Happy Birthday, Hillbilly! :D
Terry
/ Plasma Questions
Terry
Thanks Terry.
My birthday isn't until the 23rd.
I don't really care to celebrate my birthdays, other than the fact I'm still alive, but it gives me an excuse to get something I want with the wife's blessing.:cool2:
/ Plasma Questions #43
Hilbilly if you were in the welding business here in the Puget Sound area, you would need 2 or 3 of everything for back up. There are only two factory authorized repair centers in the whole area. I've had a welder in the repair shop in Seattle since the first of November! Now if I was in the welding business wouldn't that be special to have to wait this long for repairs? :rolleyes:
/ Plasma Questions
That's ridiculous!!! How long would a hobbyist have to wait?
On a positive note; at least they did not, flat out, refuse to work on it because it was an off brand.
/ Plasma Questions #45
I am glad you found the machine for you. Plasma cutting is another way of doing something that was a big step forward for me. It has saved me a *lot* of time and given me a good finish to boot. I doubt if you will be sorry that you spent the money.
Do think about your air source though, it is really important to have clean dry air, and it will probably take a mid-size (2-3 real horsepower) compressor at least to supply the air. I have two sixty gallon air storage tanks and that helps me a lot, as I can cut for 2-3 minutes continuously (which is as long as I have gone) without being concerned about air pressure.
Enjoy!
/ Plasma Questions
I think I should be ok for air volume. The xp specs state it only needs 4 scfm and my compressor is rated at 11.3 at 90 psi. Not sure about it being dry enough though. I've got a cheap air filter that I picked up from PA and I will attach that to the inlet of the plasma cutter. I'm also going to try some sandblasting for the first time and that will likely tell me if the air is dry enough.
/ Plasma Questions #47
No it is a Lincoln, the guy is amazing with these old girls!
/ Plasma Questions #48
OMG! How are you able to cope with only two SA200's?? Any withdrawal symptoms? Are you doing okay....? :D :D
Terry
/ Plasma Questions #49
Terry
What do you mean​ I'm down to only one! Had the engine rebuilt to my 1966 Red face. Got the engine back last week, but the generator is in the same shop, having dielectric put on it, and a new bearing.
This is the only engine drive I have at home! :eek:
/ Plasma Questions #50
God forbid!
/ Plasma Questions
I picked up the Powermax 30xp today and got a chance to try it tonight. I only made a few short cuts on 1/4" and 3/8" and I can't believe the difference between the 30 and 30xp. This is definitely the right machine for me. It cuts way faster than the 30 and does a really nice job. Happy days.:cool2: I sure wish I got it before my grapple build. It would have been sooooooo much nicer having it. Now I'm finished the fab work on the grapple and have nothing to use the plasma on. I guess I better come up with another attachment build idea.
SA that Lincoln welder looks like something that would be dropped out of plane over enemy territory.
/ Plasma Questions #52
Thanks for the report. I have my eyes on the 30XP and the 45. The 30XP I think is plenty for me but I like the idea of having compatibility with a CNC table that from what I understand, needs to be the 45.
/ Plasma Questions #53
Congrats. I think you made a good decision with your brand choice. I have a 15+ y.o Hypertherm and I'm thinking about getting the new (updated) torch that is available for it. How do you put a price on being able to get part's 10-15 year old welders, or in my case, plas. cutter. I just did not want to turn your thread into another "Ford vs. Chevy" argument in my earlier post here. Use good dry air like they say! I have an inline dessicant thingy that's ok. SA has a nice homebrew air dryer and I'm sure he'd be happy to show you his IIRC "trashcan full of ice":thumbsup:
/ Plasma Questions
I watched a video on Youtube where a guy used some vertical steel piping mounted to a wall just downstream of his compressor discharge and that worked well for removing moisture, for him. Since I don't do a lot of cutting, painting or sandblasting I think that might work for me and will likely give it try.
As far as brand choice goes, I have no regrets for spending the extra money to get one I have a LOT of confidence in vs spending less and wondering if/when my new machine will break down or I can't get parts.
I did cut a small plate to add some protection for the hydraulic cylinder on my grapple and used the XP to do it. What a pleasure it was to use that instead of the O/A. Nice clean cut, fast and easy. I love this thing. While this may not get a lot of use, one thing I know for sure is that I will not hesitate to cut things that I would not do with the O/A. As a matter of fact I will look for reasons to use it.
/ Plasma Questions #55
Here are some pictures of the air dryer I built. Couple years ago I upgraded to a refrigerated unit, and a new compressor. Believe it or not, the garbage can full of water drops the temperature of the air more so than the refrigerated unit! :rolleyes:
/ Plasma Questions #56
S.A, on your garbage can full of water you just come out of the comp. tank through the coil to the plas? Is room temp (say 80*) OK? You posted this for me a while ago and I was out of "roundtuit's":laughing: That's so dang simple I have no excuses not to put one together, especially if you don't need to worry about fresh cold water. (or do you).
edit; oops, I didn't look at all of your pics.
/ Plasma Questions #57
not sure if you posted this or not? but what do you set your oxygen pressure to when you cut? turning it up higher helps but speed is the answer and it is hard to do, I did pretty good when I was doing it but sense retired from where I worked for 35 years but there were some guys that were better than I was and it was because they did a lot of it, but try to run higher pressure on oxygen to blow the molted steal away better.
/ Plasma Questions #58
SA, when you had the garbage can cooler, it looks like you just ran the cooled air into the receiver tank and let the moisture drain from there. Or, did I miss a drain from the copper coil in the garbage can?
/ Plasma Questions
I was wondering the same thing. I like cheap and simple vs expensive and complicated.:)
/ Plasma Questions #60
The air comes out of the compressor pump, through the copper coils. Back into the compressor's tank. Inside the shop, and through the black pipe after cooler hanging on the wall.
Yes there is a drain in the bottom on the copper coils, Bulk head fitting through the wall of the plastic garbage can. When I'm done for the day that drain is the first one opened. Then the compressor tank, then all the ball valves at the bottom of the after cooler.
Here in the North West just water works fine. Other regions you may have to drop a bag of ice in the garbage can. I also put some of that chemical they use in water beds in the water.
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
UNUSED ATS POWER ATS-MIG-140 MIG WELDING MACHINE (A64281)
UNUSED ATS POWER...
2015 Isuzu NPR HD Septic Pump Truck (A62613)
2015 Isuzu NPR HD...
2022 Kubota SVL97-2 Compact Track Loader Skid Steer (A61572)
2022 Kubota...
2018 Navigator RT-6500 6,500lb Piggyback Forklift (A61567)
2018 Navigator...
2018 Nissan Versa Sedan (A61574)
2018 Nissan Versa...
