JD 650 no power to fuse block or lighting
   / JD 650 no power to fuse block or lighting #1
Bigr1959
Fate,TX
JD 650, MF 50
I just put a new key switch on and rewired several things. Tractor fires right up but I am not getting any power to fuse block or to lighting.
Any idea's? Is there a dedicated ground maybe I missed?
Any help greatly appreciated.
Mark
   / JD 650 no power to fuse block or lighting #2
I have a PDF of the Tech manual you're welcome to, it has all the wiring.
Shoot me your email if wanted
Joe
   / JD 650 no power to fuse block or lighting #3
If all the electrical worked well (lights, etc) before you rewired it, then I would have to suspect the rewiring that you did or the part(s) you replaced. I would suggest to go back and doublecheck all of that work. Although, I suspect it may not be so easy now since it could be different from the way it was originally. If that doesn't seem to be a problem, then maybe the new switch is just different and not providing 12v to the block? If you are certain all that is correct and not the problem, maybe you left a connector unplugged, or accidentally left a wire loose somewhere??
   / JD 650 no power to fuse block or lighting #4
Joe
Hey Joe, I know it's been a few years since this post but I just purchased a JD 650 and could really use a copy of the tech manual. I'm trying to get it up and running.
   / JD 650 no power to fuse block or lighting #5
Send Joe a pm, and include your email.
Click his username to see how to send the private message.
Welcome to TBN
   / JD 650 no power to fuse block or lighting #6
Mark
sounds like the time I purchased a new key & switch for my cub and the new switch wouldn't work so I put the old one back on. May have a new junk part.
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
2016 FREIGHTLINER CASCADIA DAYCAB (A53843)
2016 FREIGHTLINER...
2016 Freightliner M2 106 Altec AM50 50ft. Bucket Truck (A55852)
2016 Freightliner...
X-CEL GOOSENECK TRAILER (A54756)
X-CEL GOOSENECK...
