   / Harbor Freight Tools that don't suck #4,311
I have a Chicago Electric Arc-180 130 amp AC/105 amp DC arc welder. I know it is no longer made, or at least no longer sold by harbor freight. I need a new main power switch (the magic blue smoke got loose from my switch). I've already emailed HF customer support, and am still waiting; but the basic question is... do the sell replacement parts for discontinued models?
Failing that I'm going to try to figure out a simple ghetto way to switch the main power and eliminate the fan, power on light, and over heat light/thermostat.
Edit: I'm surprised I smoked the switch, wasn't hot, and I wasn't running it too hard I didn't think; 1/8" 6011 at max amp, made it about 2/3rd threw the rod and I heard a couple "pops" from switch.
Edit-edit: I should mention, the book and all info lists 130/105 as max amps, but the machine it's self lists 160/135 (I belive, not looking at it right now) as the max; and that's what I had it at. Don't know if sticker or manual is right. Also; unrelated; but the Arc-180 name is a bit miss leading, and the guy I bought from on Ebay listed it as an arc welder, 180 amps....
   / Harbor Freight Tools that don't suck #4,312
HF doesn't even sell replacement parts for their current models as best I can tell. If I were you I'd take the old switch to an electrical supply store and see what they can do to match it.
   / Harbor Freight Tools that don't suck #4,313
I'm going to give the trailer jack below a qualified two thumbs up. It's perfect to roll around my empty 16 ft, 1500 lb trailer in my barn with a cement floor. For that use it's perfect.
If you want to leave it loaded to the gills with weight and roll it around very much you will likely have a problem after a few uses. It's not heavy duty enough or designed for that type of use. If this is your use, don't buy it.
1500 Lb. Capacity Dual Wheel Swing-Back Boat Trailer Jack
It shows it's $29.99 but sometimes it's on sale for $25 and with 20% off you can get it priced even better.
   / Harbor Freight Tools that don't suck #4,314
HF WEBSITE HIJACKED !!!
Sixdogs link above shows HF, but clicking it took me to
It's a trap!
Reported phishing or malware site
This web site at emjcd.com has been reported
as malicious and has been blocked by your Internet Service Provider.
MCafee reports that 100% of the reports to Mcafee from users describe emjcd as virus or unwanted popups.
   / Harbor Freight Tools that don't suck #4,315
Check your computer for malware, the link goes to http://www.harborfreight.com/1500-lb-capacity-dual-wheel-swing-back-boat-trailer-jack-67500.html for me, NOT to the site you linked.
Aaron Z
   / Harbor Freight Tools that don't suck #4,316
Thanks for the reply. It could be here - this AM I changed DNS from ISP default, to 8.8.8.8 (google) after images.frys.com not found.
I'll investigate here.
Did anyone else get that redirect?
   / Harbor Freight Tools that don't suck #4,317
HF is opening a new store in Medina soon. Oh Boys!
   / Harbor Freight Tools that don't suck #4,318
Years ago I ordered some things from Harbor Freight's catalog and of course got the stuff from California. And now . . . I have 3 of their stores within 30 miles, one only about 4 miles from my house.
   / Harbor Freight Tools that don't suck #4,319
This is the only store in this county far as I know. Be scared having a lot of stores.
2023 MAXXD TDX Drop-N-Load Trailer with Air Ride Suspension and Tilt Deck (A52128)
2023 MAXXD TDX...
2018 INTERNATIONAL 4300 BOX TRUCK (A51222)
2018 INTERNATIONAL...
Stump Grab Bucket (A50322)
Stump Grab Bucket...
CATERPILLAR D6R XL CRAWLER DOZER (A51242)
CATERPILLAR D6R XL...
2021 Kubota RTV X900 4x4 Utility Cart (A50322)
2021 Kubota RTV...
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
