I need JD 4200 injector pump part # help.
   / I need JD 4200 injector pump part # help. #1
stingray1
East Tennessee
John Deere 4200 w/backhoe, Ford 3000,Case 580 backhoe
I have a 2000 4200 engine 3TNE78A-EJTS the Yanmar injector pump part #719923-51470 I found a super buy on a new pump part #729223-51480 the seller says he thinks it will fit,but I'm not sure if anyone can help any advice would be greatly appreciated. Thanks
Any help is appreciated.
   / I need JD 4200 injector pump part # help. #3
Didn't you get an answer already in the other thread you started? Why do you need a new IP anyway?
No,but I take it from your reply that you think I did. Should I not have posted the same question in both the JD and Yanmar sections? I'm just asking for some info/help,not a scolding. If I'm reading your reply wrong I apologize and if you can help I do appreciate it.My old IP is leaking fuel into my crankcase(the pick up pump is checks/looks good) I can get this new surplus IP with the fuel shut off sol.and pick up pump for $180 shipped. If this IP will work I feel this would be cheaper/faster than repairing my old pump,but I may be wrong,that's why I ask all the questions and posted in both sections. Thanks for your time.
2016 Ford Fusion SE Sedan (A59231)
2016 Ford Fusion...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
CAT Chassis Only (A59076)
CAT Chassis Only...
Ratchet Straps (A59230)
Ratchet Straps...
2004 AGCO Gleaner 3000 Corn Header (A56438)
2004 AGCO Gleaner...
Case skid steer wheels and tires (A56438)
Case skid steer...
