How to run and mount 3rd function lines/hoses
/ How to run and mount 3rd function lines/hoses #1
kspring61
Now Western TN
Kioti DK40SE HST Ford 8N
I am installing my 3rd function I got from EA. It comes with a bracket that mounts the valve on the back left of the tractor. Just wondering if anyone has installed this kit on a DK40SE HST and if so any recommendations on running the hoses up the FEL and how to attach them to the FEL arms. I haven't laid out the hoses yet but looks like since the valve mounts on the back left I will have to run the hoses up the left side of the FEL. Looking at that side not quite sure how I will be mounting the houses to the FEL arm.
/ How to run and mount 3rd function lines/hoses #2
On my CK35 the hoses run along the loader arms on the Right side following all the factory gear. You could do the same and cross the lines over to the left at the rear of your DK. My valve is also mounted on the right rear of the tractor, but I don't see why you couldn't cross them over on yours. Zip ties are the easy way to attach your hoses from front to back.
Thanks, I have seen that before. But totally different tractor and valve location. Also he doesn't talk about running the hoses and best way to attach to the loader arm.
Just looking to see if someone has a lessons learned or good suggestion for running them on a DK40SE
Yea I was thinking that. I need to be sure the hoses they sent me to go from the 3rd function valve to the loader are long enough to cross-over underneath. Wont the zip ties chaffe the hose lines? I would think the hoses would move slightly in the zip ties. If not then I will do that and zip tie them to the loader lines.
/ How to run and mount 3rd function lines/hoses #6
Buy some of these hose clamps and mount on top of the factory ones along the loader arm with longer bolts. Works out nice,
That's a good idea. Not sure I can mount them on the factory mounts, mine are hard line mounts, but will see if that works. If not I may use these anyways and mount right to the loader arm
/ How to run and mount 3rd function lines/hoses #8
Zip tying the hoses to the hardlines is a tried and true method to run the 3rd function hoses.
/ How to run and mount 3rd function lines/hoses #9
Yes, I should have mentioned, my hoses are in a protective fabric sheath, similar to the factory hoses on the loader. So far I can't see any signs of wear and tear for the zip ties.
/ How to run and mount 3rd function lines/hoses #10
Ditto - ain't Kioti specific you just have to lay it out and "mock" it up then go back and cinch down tight after you have the hoses exactly how you want them.
/ How to run and mount 3rd function lines/hoses #11
If you are worried about chaffing at the zip tie points (shouldn't be an issue) then just wrap the hose a few wraps of good electrical tape at the point the zip tie wraps around it.
/ How to run and mount 3rd function lines/hoses #12
Kspring,
Please take photos of your project, especially where you make your connections to the existing Kioti valve. I'd be very interested in seeing these.
I'm running a set of lines from my existing ports on the rear for now. I plan to use the hose block like Countrybumpkin suggested. I'm getting mine from Surplus Center. I believe I will only need to remove one of the existing bolts on the current hard line block and install this over and use a longer bolt???
You know, with JD now offering these 3rd functions as factory options, wonder when Kioti will offer this from the factory??? Hmmm....there's an idea??!!
Good luck!!
/ How to run and mount 3rd function lines/hoses #14
I believe I will only need to remove one of the existing bolts on the current hard line block and install this over and use a longer bolt??? !
that is what I have in mind to mount my hoses. The fittings for the loader valve and the rear remote block should be here in the morning for my setup and I have the mount built for the solenoid valve to set on.
/ How to run and mount 3rd function lines/hoses #15
Good luck!!
I second the request, please take pictures as I am in the same boat running hoses off the rear ports.
What size of line are you using?
The lines from the loader vavle to the 3rd fucntion valve and the line from the 3rd function valve to the rear hydro is 1/2"
Line from the 3rd function valve up the loader to the grapple are 3/8"
Here is the kit:
Started installing it today and have already ran into 2 problems.
1) The bracket with the 3rd function valve on it doesn't seem to be correct, seems it doesn't have enough drop to it causing the 1/2 lines to hit the underbody of the tractor.
You can see there is no way I would have had room to get those lines on if I mounted the valve first. You can see the bracket isn't flush with the rear mounting surface of the tractor.
I put the hoses on the valve first given there isn't much room in there to get a wrench on the hoses once you mount the valve.
2) Not sure how to get the current handle off the control lever for the FEL, seems to be glued on or something, no screw to loosen and I tried just unscrewing the handle thinking it may be threaded. No luck. Anyone know how those handles are mounted on there?
What I thought would be the hardest part, getting the old solid line off and new lines on the loader vavle was actually pretty easy. Here is the 90 degree adapter they give you mounted to the loader valve.
Here is the adapter on the rear hydro unit (this is where the power beyond line went).
I haven't got to the part of running the lines up the loader arms, but may mock that up now and see what I need for that. Right now I am leaning towards running them up the left side just because there doesn't seem like a lot of room left on the right side underneath with the current loader valve and 4 lines running up the FEL.
/ How to run and mount 3rd function lines/hoses #17
These two pictures explain exactly what I wasn't sure of, thanks!
Good work!
OK , I got the bracket and valve mounted but the hoses are up against that underneath part of the tractor fender, so taking a run to Home Depot. Thought is I will use some foam wrap like you use to insulate pipes around the hoses to stop them from rubbing.
I dont think the handle on the FEL lever comes off, the new handle is actually longer, so I think I will be cutting off the old one.
Also mocked up the hoses on the FEL and I think I have the mount points figured out.
I'll post all the pics once I get it done
/ How to run and mount 3rd function lines/hoses #19
Looks like it coming together, I started my install today I'll start a build thread in a day or so on mine.
/ How to run and mount 3rd function lines/hoses #20
Nice job Kspring!!! Thank you. Excellent photos. Before you button it all up, can snap a couple of all the lines installed?
2024 JCB 35Z-1 EXCAVATOR (A65053)
2024 JCB 35Z-1...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
Timpte 720 All Aluminum 7000 Tilt Trailer (A63689)
Timpte 720 All...
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
