Snow Equipment Owning/Operating Cutting / Groving / Siping R-4 for snow
   / Cutting / Groving / Siping R-4 for snow #391
Bingo!!
Well if you were closer, I'd let you use my groover.
Anybody know of a autoparts or tire store that will rent a groover??
Or anybody want to rent theirs? If you're in upstate ny I'll come get it.
I really think both my Kioti's would benefit from grooving. 2003 CK 20HST and 2014 CK2510 HST cab, with front blower.
   / Cutting / Groving / Siping R-4 for snow #392
Is it possible to use a grooving tool in cold weather? I don,t have a heated place to work on my tractor. My 400ft. gravel driveway has a layer of ice under the snow, and i was able to backblade and bucket it out of there, but a lot of spinning and sideslip. After reading about grooving I am convinced it works. I.m really not fond of chains. The tractor is a TC33 NH gear.
Thanks, Bill
   / Cutting / Groving / Siping R-4 for snow #393
It will work but it will be slower. The warmer the tire the better. At 60* my tires cut like butter. If anything I'd blast a heater on the tire you're working on. It'll keep you and the tire warm while to work.
The tool has a nose on it to actually warm the rubber before the cutter gets to it. Its not just the hot blade that does it all.
   / Cutting / Groving / Siping R-4 for snow #394
Most dirt racers have this tool they usually groove their tires in a specific pattern. You might need to buy a wider grooving blade.
   / Cutting / Groving / Siping R-4 for snow #395
OK, I read this thread and followed all the posts and went ahead and bought a groover.
I did all 4 tires and it took about 45 minutes per tire at 20 degrees. I'm anxious to try them during the next snowfall. I did this on a JD2720.
2-3-2015 Rear Tires Grooved 4.jpg2-3-2015 LF Tire Grooved 6.jpg2-3-2015 LF Tire Grooved 6.jpg
Many thanks to all the contributors of this thread. I could not fit chains on my tractor since I have the optional mower lift option and hope this takes care of my traction issues without the need for the expensive spacers and tire chains. My tractor does "OK" for the most part but has also disappointed me in certain snow/ice conditions.
You guys are a blessing.
   / Cutting / Groving / Siping R-4 for snow #396
I gotta ask. How wide are the grooves you guys are cutting? That look MUCH wider than the 1/4" groove mine does
   / Cutting / Groving / Siping R-4 for snow #397
Mine are supposed to be 1/4 inch wide give or take a couple hundreds. I used the #4 blade and tip. I used 3/8 inch depth for the rears and 5/16 for the fronts.(my fronts and rears have less than 200 hours on them)
From eyeballing mine I'm sure they aren't any wider than 1/4 inch. I can measure them tomorrow.
   / Cutting / Groving / Siping R-4 for snow #398
View attachment 410044View attachment 410045View attachment 410045
Boy, you did a really nice job!!
   / Cutting / Groving / Siping R-4 for snow #399
I measured the groove width today and it came out to .230
   / Cutting / Groving / Siping R-4 for snow #400
I joined "Club Sipe" today:
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
1980 ATHEY AB6905 MOTOR GRADER (A52707)
1980 ATHEY AB6905...
DETROIT DIESEL ONE BOX (A55745)
DETROIT DIESEL ONE...
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
2005 Tennant ATLV 4300 Turf Vacuum (A55851)
2005 Tennant ATLV...
30pc. 16ft.x 3ft. Grey Metal Roof Panels (A53424)
30pc. 16ft.x 3ft...
