LOADER USE
   / LOADER USE #11
Hi Everyone.
I would be the "My son" the OP mentioned. Thanks for the replies thus far.
To address some questions / concerns voiced thus far:
The tires are loaded and we are in the process of building a ballast box as well.
Bale size will mostly be 4x4 (maybe a 4x5). We are "hobby farmers" and will most likely only be moving 2-3 bales a season at most and not for very long distances. We don't really need to lift for a lot of height to stack / unstack but being able to unload a roll from a truck/trailer would be nice. I'll just push/drag it off and then pick it up w/ the 3pt if I have to. :D
The reason he said "forks" vs spear is that being such low use we're looking to use multipurpose attachments instead of buying a lot of different "job specific" ones.
Right now this one (SpeeCo Ultra Fork) is my leading choice as we can use either the loader or the 3pt as the size/weight dictates for bale movement, still have limited pallet fork capabilities, and also use the forks to move some brush / debris.
Thanks again for the advice and info. Please keep it coming.
I can vouch for how handy the UltraFork is. It should work fine for the 4" bales.
I had to add a longer spear for the 1400 pound, 5x6 bales that we use.
I added angle brackets for picking up the 2000 pound feed bags, a light duty receiver hitch for moving bumper pull trailers and a heavy duty receiver hitch for gooseneck trailers.
   / LOADER USE #12
Put chain hooks on that fork...you will never regret it. I note that there is not a "roll back" barrier...so DO be careful when lifting ANYTHING very high....it can come back on you.
Putting a hydraulic top link on the tractor could be the single best additional item...really helps in getting the right "tilt" when using a bale fork on the 3ph. I have one, highly recommended.
Welcome to TBN, "son"....:D
Thanks. :)
We actually have some hooks lying here to put on the bucket, if we end up with this fork, we'll add some to it as well. Waiting for the local Southern States Co-Op to get back to me on a price. They don't normally carry / stock that fork so he's e-mailing SpeeCo.
I'm with you on the top link but I haven't quite talked Pop into adding the rear remote kits yet - trying to twist his arm into a 3rd function on the FEL and a EA 50" Wicked Root Grapple first.
If I can't talk him into that and end up working brush with the forks, then adding a shield with some flat bar stock and stretch metal is definitely first thing on the agenda.
   / LOADER USE #13
Xfaxman -
Thanks for the pictures and the recommendation!! I think for our use it will be a very handy item as well.
   / LOADER USE #14
This is how I do it.... I put a rear mount (3ph) spear on the back and spear up a round for ballast then I have a front spear that goes on my bucket so one on the back and then one on the front. Got both spears at TSC BTW. Now, I typically handle high density 4x6's but my tractor is much larger than yours. (Kubota M9000).
I'd go with the front and rear spears plus the rear spear has a 2 1/2" ball on the top for moving gooseneck trailers around....
   / LOADER USE #15
I have the Bobcat vesrion of the CK27, same frame & wieght but little different loader. I handle 4X4 mixed grass bales 1 per week with no problem. My R1rear tires are filled and set out to same outside width as R4s. I have on ocassion picked up a bale to feed with no rear ballast but when I do I make sure I am not lifting to dump it in the bunk while setting on any side slope. My loader is rated @ 1480 lbs. compared to your 1074# but my max lift height is 3" less. Stability at full lift height is part of the capacity calculation, no idea how much the additional 3" lift reduces actual abilty.
I have no problem in height to unload from a trailer. My hay supplier brings it in on 30" Goose neck trailer and loads 2 high on traailer plus 1 bale on the upper deck and I can lift them off easily.
If you get that combination fork/bale spear, spear the bale to pick it up. Much easier to pickup and keep control of the bale versus using pallet forks. I do use my pallet forks occasionally but seldom, bale spear works so much nicer.
I will be getting some 4X5 bales later in March because my regular supplier ran out. I know I can pick them and move OK, just have to go slower.
For the few bales you plan to handle you should be fine, just don't get in a hurry and use adequate rear ballast on the 3pt.
   / LOADER USE #16
I notice you have a Century Livestock polyethylene feeder. How are you liking your so far? We've had ours for about 2 years and it's held up great. No more broken welds or bent up metal to fix.
   / LOADER USE #17
Have had it about 3 1/2 years, like it. Much better than the steel ones. It is the 4 ring Horse Feeder.
This is the Cattle Feeder, if you use it for horses, they will rub a lot of their mane off, reaching in under the top ring.
Century Livestock Feeders
   / LOADER USE #18
The second one, which is for cattle is what we have. We have scottish highland and those horns are **** on everything.
   / LOADER USE #19
Wow!! $675 for the UltraFork. Ouch. Think I'd rather buy a cheap(er) 3pt spear and put the rest of the $ toward a grapple. LOL
Thanks again everyone for all the info, advice, and guidance.
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A55787)
2017 Caterpillar...
23013 (A55787)
23013 (A55787)
2015 Mitsubishi Outlander Sport Multipurpose Vehicle (MPV), VIN # 4A4AP3AU0FE026699 (A56859)
2015 Mitsubishi...
(INOP) RHINO 1310 ROTARY CUTTER (A52708)
(INOP) RHINO 1310...
2006 FORD F-150 PICKUP (A58017)
2006 FORD F-150...
(2) CIRCULAR SAWS (A58374)
(2) CIRCULAR SAWS...
