John Deere 110 TLB
/ John Deere 110 TLB #1
fmos
Cleveland Texas
JD 110 TLB
I purchased a John deere 110 TLB, it didn't have the 3rd function hydraaulic control, does anyone know if it can be added, I know there is not a kit available.
/ John Deere 110 TLB #2
Welcome to TBN,
You want it for the loader or hoe?
Either way you will have to built it from aftermarket parts as there are no "kits" available as you wrote. A diverter setup will be the easiest way-you can divert the dump/curl circuit on the loader, or the outrigger circuit on the hoe.
/ John Deere 110 TLB #4
Here is a diverter valve for a grapple using the curl circuits hyd.
SAE 12 15 GPM DOUBLE SELECTOR VALVE 12VDC P15438-2
http://www.surpluscenter.com/_MoreSpecs/dr9-7738-a.pdf
http://www.surpluscenter.com/_MoreSpecs/i9-7738.pdf
Here is a 3rd function.
12 VDC 10 GPM OC DA SOLENOID VALVE
1 STATION DO3 SUBPLATE OPEN CENTER
Hydraulics:
Type: open center
Capacity: 15 gal [56.8 L]
Pressure: 3000 psi [206.8 bar]
Total flow: 23.6 gpm [89.3 lpm]
12.2 gpm [46.2 lpm] (loader)
16.3 gpm [61.7 lpm] (backhoe)
/ John Deere 110 TLB #5
I want it for the loader
Adding a new valve will be difficult with the 110TLB since the lines are well protected. IMHO, your best bet is a diverter setup that basically "diverts" or "splits" the dump/curl circuit into a new on when a momentary button on the joystick is held.
We sell a unit that will fit the bill perfectly: Ken's Bolt on Grab Hooks <<Hydraulics>>
I can send more info if you contact me through the website.
Thanks, Looks like everything is there that's needed.
New Three Point Hitch Trailer Mover (A65579)
New Three Point...
2005 GMC C5500 (A64127)
2005 GMC C5500...
New/Unused AGROTK YC-32G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
1999 John Deere 5410 (A64126)
1999 John Deere...
BUCK STOVE FIREPLACE INSERT (A64276)
BUCK STOVE...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
