Kubota 7200
/ Kubota 7200 #1
Mcfclz
Bristol ct
Kubotab7100
What is the proper procedure for connecting on board hydraulics to FEL and BH on kubota 7200
/ Kubota 7200 #2
Do you have a manual for your tractor?
I looked up data for a B7200 if that is what you have.
It does have a hyd block.
That is where you connect the loader
/ Kubota 7200 #3
:welcome:
To the forum from Alabama.
/ Kubota 7200
Will I need more hydraulic reservoir capacity!
/ Kubota 7200 #5
No, you will use the fluid in the tank after you fill all the lines and cyl.
Once you operate the loader, and bleed all the air, just replenish the tank fluid.
/ Kubota 7200
Thanks for the info!! Much appreciated
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
PALLET FORK MOUNT SAFETY BASKET (A61572)
PALLET FORK MOUNT...
Rol-Air gas powered portable air compressor, Coal Valley, IL (A65640)
Rol-Air gas...
18.4-42 Tires (A65640)
New/Unused Quick Attach Pallet Fork Frame (A65583)
New/Unused Quick...
Covered Livestock Mineral Feeder (A66408)
Covered Livestock...
