Another Plasma Cutter Question. 20a 220v Power Limitation
   / Another Plasma Cutter Question. 20a 220v Power Limitation
Success, Hypertherm PowerMax 30 (and adaptor plug) ordered. Thanks everyone for your input...
   / Another Plasma Cutter Question. 20a 220v Power Limitation #12
You're going to love it. Now you need to be sure to feed it the cleanest and driest air you can.
The electrodes and nozzles will last a lot longer, with better air. And the cut quality will be better too.
Gotcha, I have a dryer at the compressor but will fab an additional quick connect dryer for use at the plasma cutter. I have a similar set up for my blasting cabinet. Thank you..
   / Another Plasma Cutter Question. 20a 220v Power Limitation #14
Then you are all set. If you don't get any water at the quick connect filter, the you might not need it.
Plasma Cutter arrived, that was quick. Now to try it out....
   / Another Plasma Cutter Question. 20a 220v Power Limitation #16
Eagerly waiting for your initial review and some pics or video.
   / Another Plasma Cutter Question. 20a 220v Power Limitation #17
I too eagerly await your report including photos....
2007 Ford F350 Super Duty (A50514)
2007 Ford F350...
John Deere 4020 Tractor (A50514)
John Deere 4020...
2000 PETERBILT 379 FLATBED TRUCK (INOPERABLE) (A50854)
2000 PETERBILT 379...
BOMAG BW5AS DOUBLE DRUM COMPACTOR (A51242)
BOMAG BW5AS DOUBLE...
2012 GMC SAVANA BOX TRUCK (A51243)
2012 GMC SAVANA...
2022 BANDIT 2550TK STUMP GRINDER (A51242)
2022 BANDIT 2550TK...
