BX toplink mods
/ BX toplink mods #1
Scooby074
Super Member
Nova Scotia
BX 25, ZD 326
Just a couple easy little mods here to take care of some annoyances with the factory BX top link
First is to add a couple grease fittings. Under the black caps, there is a hole that is used to push in a roll pin when the link was built. This hole is just about the right size for a 1/8NPT grease fitting. I tapped the hole with a 1/8 NPT tap, no drilling required. There is a fair bit of clearance between the tube and the adjusting screw inside, the threads only go about 1" up the top link tube.
Now I can squirt a shot of grease in there once and a while to keep things smooth.
Second was to add some handles to the link to allow for easier adjustment, the welded on chain link is basically useless. The handles are 5" long, 1/2" round.
Lubed with some Cat 5% moly
Installed with a fresh coat of Kubota gray
/ BX toplink mods #2
Good pics. The handles really make life easier. It is so annoying trying to hook something up and not be able to connect the toplink because you can't turn it.
/ BX toplink mods
I think the handles will be a great help. Not only is it annoying to hook up things, but its also difficult to adjust the TL while in use, like when using a Box Blade. I think the handles will be as close as you can get to a manually operated hydraulic top link.
/ BX toplink mods #5
Yeah so why do they make the top link so hard to turn?
They make it easy to turn. It's the pressure on the link that makes it hard. Raise or lower the implement just a whisker and it will move like butter. A better way is handles like Scooby has.
/ BX toplink mods #6
Any concerns about grease building up inside and reducing adjustment? Or will you just take it apart periodically (once every 10 years) and clean it.
Doug in SW IA
/ BX toplink mods #7
It is always nice to see improvements to consider. Thanks for posting.
The handles would be a great help. My concern is that they would interfere with the PTO shaft or lift arms if they slightly rotated. My method of adjustment is to use a short crowbar and stick it through the "chain link" that is welded to the body.
The crowbar is kept in a piece of heavy-duty PVC water pipe held on to the ROP with screw clamps. BTW a fire extinguisher is carried on the other side of the ROP with a really large plastic pipe and screw clamps. Maybe I'll get a photo later.
Of course, another solution to the top link issue is to buy a cheap one and grind down the balls to fit in the narrow BX mount.
/ BX toplink mods
I find the threads on the TL need a lot of lube or they bind up with weight on it. The way that Kubota designed it, with that welded on link that you jab a screwdriver through wasnt very well thought out IMHO. Its not convienient always having to find a tool to move the TL and it makes it really slow to adjust with all the re-positioning of the screwdriver or prybar when doing the adjustment.
/ BX toplink mods
Doug in SW IA
I predict that the TL might see 2 squirts of grease a year if that. The fact that there are through holes there to pound in/out the roll pins means that even though one side is plugged with a grease fitting, the other side has a loosly fitting plastic plug so you should never end up with a situitation where the grease causes it to lock because you can never get enough hydro pressure to cause it. If the pressure ever builds that high the plastic plug would shoot out I think. That whole tube is basically hollow with just a small set of threads on each end so there is a lot of volume in there you'd have to fill before this becomes an issue.
/ BX toplink mods
I was concerned with clearance too. But with the snowblower on there with its PTO, so far clearance isnt a problem for the TL and the PTO or 3pt. If an issue comes up, a few minutes with a hacksaw to shorten the handles is all it would take.
/ BX toplink mods #11
Great idea's. Now what are you gonna do about the sidelink;)
/ BX toplink mods #12
Looks like a great idea! I might have to do mine too. I've made all of my own brackets for lights and switches, so this should be easy. I was actually going to buy one with the handles, because I feared the stock one might be too thin for welding. I was wrong. ;). Thanks for being the test dummy. :D
If it ever interferes, I'd bet you could knock it back to 3" and still get all the leverage you need for a BX.
/ BX toplink mods #13
I added grease fittings to mine tonight. Thanks for sharing the idea:thumbsup:
/ BX toplink mods
The tube is quite thick actually. Fire up the welder lol.
3" would probably be plenty, but 5" hasnt caused any issues yet, so a little more leverage is a good thing.
/ BX toplink mods
Lol.. I might have to do something with it. Drill a couple holes and install some fittings . Not sure if I have clearance for much of a handle though. Ill have to look at it. The side link might be even more stiff than the top link
Looks good. I would have used straight grease zerks too but I didnt have any the right size.
/ BX toplink mods #16
IDK if grease fittings could be added to the sidelink. They may rub the threads. I have an old wrench that was cut off that is perfect for adjusting the sidelink. I keep it in the BX's toolbox but the toolbox is not on the tractor yet:laughing:
/ BX toplink mods #17
...I have an old wrench that was cut off that is perfect for adjusting the sidelink. I keep it in the BX's toolbox but the toolbox is not on the tractor yet:laughing:
I think it's Harbor Freight that has a stubby adjustable wrench that's perfect for the B and BX. It's either this one 2 in 1 Wide Mouth Adjustable Wrench or one I got at Lowes. It opens wide and stores in a small space.
/ BX toplink mods #18
Nope. It was still tough as nails even when the top link was disconnected. So I just don't get it.
/ BX toplink mods #19
When I tighten my top links I make the nut just a little tighter than hard finger tight. In use they tend to tighten themselves so if you over tighten from the start they will be very hard to get loose. Maybe?
/ BX toplink mods #20
Sorry, six dogs, but I'm afraid that the nuts are loose when I try turning the top link. It just seems to be that the threads are extremely tight or may be misaligned or something like that.
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
MacDon 963 Draper Header (A63688)
MacDon 963 Draper...
2013 CORPUS 40FT  T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
2005 SBX-5 Box Blade Tractor Attachment (A61572)
2005 SBX-5 Box...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
40' Used Container, High Cube, Single End Doors (A62679)
40' Used...
