L Series owners
/ L Series owners #1
Hagalaz14w
Member
Mexifornia
Kubota L3200
Seems most people here own a BX series Kubota.
Any L series owners here? I'm a first time tractor owner with a nearly new(13 hours when I bought it)L3200. Any advice or suggestions?
/ L Series owners #2
I have a 2002 L-2600 Bought new in 2001. Very dependable, no issues, never been to shop.
/ L Series owners #3
I have the 'brother' to your l3200, the l3800 and haven't found much work it can't handle. The jerky 3 pt system, it's only flaw, was tinkered with by a Kubota regional service rep and made the issue very manageable with a minor side effect being a slight drop in elevation of a 3 pt implement when the front loader valve is max'd out on a bucket curl. Not a big deal to me as I don't typically use the 3 pt and loader concurrently.
An extremely reliable and rugged tractor. I'm confident you will be pleased with your purchase.
/ L Series owners #4
Lots of L owners here including my L4300. A real workhorse that's priced a little better and with fewer electronics to cause problems. Works for me.
Some are a little light in the front and benefit from added weights. I found that New Holland skid steer weights fit perfectly and are cheaper since I can buy used or imports. It's only weight, after all. My weight bracket and grille are home made and the first photo is maybe 8 or so years ago when it was newer.
/ L Series owners #5
Former L3400hst owner here. I would be willing to bet there are thousands if not 10's of thousands of L series Kubota, members.
/ L Series owners #7
L4600 here.
You have an excellent machine without the emissions stuff, you are gonna love it.
/ L Series owners #8
Some are a little light in the front and benefit from added weights. I found that New Holland skid steer weights fit perfectly and are cheper since I can buy used or imports. It's only weight, after all. My weight bracket and grille are home made and the first photo is maybe 8 or so years ago when it was newer.
My dad has an L3000 that looks very similar to that body style.
He also just recently bought an L4600HST
/ L Series owners #9
Bought new L2800 in 08 here, im always amazed at what it has done and what it can do. Built like a rock, never failed to do what I need. ONLY prob I had was that rubber tube by your right foot cracked and made the hydraulics act up until I got a new hose. Other than that its been perfect. I wouldnt hesitate to but a L series again.
/ L Series owners #10
Tons of L owners here. I'm on my second. They are not quite as common as the B's but that is just the nature of the sweet spot of the CUT market. That B size covers most homeowner/hobby farm types quite well so there are a lot more out there. When you get a bit bigger property or other needs (in my case - logging work on my land) then you get into L's...
/ L Series owners #11
:welcome:
To the Forum from Northwest Alabama. I have a L3200DT I got new in March of 2014. Great machine but only has 89 hours thus far.
/ L Series owners #12
I have L2800 done everything I ask and than some.
I have heard some L2800 and L3200 fuel gauge don't read exact amount showing,off 1/4 or better on low side.
/ L Series owners #13
I have 2003 L2600DT with 229 hours. Bush Hog FEL. Love my tractor! I wish motor entry was different from side panels, but great machine.
/ L Series owners #14
There have been threads on this involving most all Kubotas. If yours is like that, the gauge stays on full a long time, then precipitously drops until about 1/4 and then slows after that. All mine are like that so I just take it in stride. Actually it's taken a few years but I think I prefer it that way.
/ L Series owners #15
That's exactly how the gauge acts Sixdogs.
"I just take it in stride. Actually it's taken a few years but I think I prefer it that way. "...same here.
/ L Series owners #16
Very happy with my L3800 and bh77 backhoe purchased in 2011. No serious problems at all to date. :) I have the beet Juice in the rear tires which is very needed. A full bucket of damp soil/gravel will not lift the rear end but will take enough weight off the tires to cause slippage. I call this a danger zone as you feel stable and all four tires are on the ground :cloud9: but you are real close to being unstable. :ashamed:
Front tire pressure was a costly mistake. I think the manual says 22 lbs. I am still working on best psi so I don't have a good recommendation yet, but with 22 lbs. and a full FEL the tire bead on right front kept failing. :thumbdown: That might be a good thread "what front tire pressure do you use for FEL work". :anyone:
One thing with the backhoe. It is getting easier with practice. :thumbsup: The first few times can seem like a challenge. :censored:
/ L Series owners #18
For air pressure in a tractor with a front loader you need way more pressure than 22 up font. My L doesn't have a loader but if it did would think about 30 and more. I run 30 in my Deere TLB 790 and 40 in a much bigger tractor.
/ L Series owners #19
L4330 here. It's 10 years old and always starts for me.
/ L Series owners #20
Our L3240 is the perfect size for our situation. Cuts the field, tills the garden, moves pallets of firewood from blocking & splitting area to house, skids logs, chips the limbs that don't get fed to the stove, builds & maintains woods road & driveway, clears snow and handles a 9' hoe. I still can't believe how little fuel it uses after a hard days work. Love that machine. Bought in 2007 and already paid for itself in chiropractor avoidance.
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A65053)
2021 CATERPILLAR...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
MARKER LIGHTS (A64276)
2018 HINO 338 KNUCKLE BOOM TRUCK (A63276)
2018 HINO 338...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
