Loader Kubota b2320 3 fonction valves on loader
   / Kubota b2320 3 fonction valves on loader #12
Yeah! If you have it I would like to take a look!
Maybe someone now where I can download a "shop repair manual" for free? I found this one on the internet https://www.tradebit.com/filedetail.php/155142258-kubota-b2320-b2620-b2920-compact-tractor-workshop. But it's 20$.
I thought the diagram was of the tractor but it is a pdf of backhoe installation instructions. It documents the installation of the hydraulic lines conversion on pages 14 and 15. I think you could adapt this part to getting your line plumbed in for a 3rd function.
Oops. I can't upload it. It's a little too large for this site. If you pm me your email, I can email it to you.
Regarding the shop repair manual I don't know of a free site, but $20 is probably worth it if you can't locate a free one. The actual users manual is pretty good for maintenance tasks.
   / Kubota b2320 3 fonction valves on loader #13
Be aware, that if I disconnect the backhoe, the two lines must be connected together. You would need to do the same if you disconnected 3rd function.
   / Kubota b2320 3 fonction valves on loader #14
For 721 you could have a remote added to the rear, just run lines to the front
Yeah, I already have a remote at the rear, but I use it most of the time. I will check for the selenoïde valves on the curl cylinder, look to be the simplest idea.
Thank's!
RING 2 STARTS HERE @ 9:15 AM (A58375)
RING 2 STARTS HERE...
2022 FORD E350 BOX TRUCK (A57880)
2022 FORD E350 BOX...
JCB 2145 (A47477)
JCB 2145 (A47477)
2016 Ford Fusion SE Sedan (A55853)
2016 Ford Fusion...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2003 Big Tex 10PI...
