Stihl MS 261 C-M 18" vs 20" Bar
   / Stihl MS 261 C-M 18" vs 20" Bar
As I only use a saw a few times a year, I always perfectly clean and oil the saw, and sharpen the teeth after every use, never know when I might need it in an emergency. Thanks for the tip on the loppers, I might give my current loppers to my son-in-law and pick up the Fiskars for me. :p
   / Stihl MS 261 C-M 18" vs 20" Bar #22
Done, LOL, purchased a new MS 261C-M with 18" bar, hard case, 9 ply chaps, cut resistant gloves, helmet system, bar oil, pre-mix fuel, files, etc. etc.. Thanks everyone for your help. Long, long overdue (especially on the safety items) , guess I'm getting a bit wiser in my old age.
Congratulations, I really like my MS261. I have a 20" bar for soft wood and it runs it fine in that wood, sits fine too. But for all around your 18" is perfect. By the way, what model was your old saw?
   / Stihl MS 261 C-M 18" vs 20" Bar #23
I was at the hardware store today and checked out the new pro saw MS241 and MS 261. THE 241 is nice and light. But a 3.9 hp the 261 is pretty light. My 361 never tires me out hauling it around i think you'll like the 261.
Curious what you thought of the MS241. I am looking for a live-aboard saw for my tractors when I come across something that needs to be cut, cleared or whatever. Wind fall, etc. My 261 and 441 seem too large and my MS192T too small. I am looking for a 14" bar, maybe 12", but enough power that I don't have to baby it like the 192. Did you run the 241?
   / Stihl MS 261 C-M 18" vs 20" Bar #24
It looked like a pretty descent saw i didn't check to see if the oil resivoir was plastic or metal like the other pro saws. Thought of it after i left. It was significantly lighter than the 261 which is not really much lighter than my 361. The 261 is definitely lighther than the 362 which seems to have gained weight with all the new emissions and just enough horsepower to keep the power to weight the same.
I didn't get a chance to run it, i dont know any dealers who demo saws around here.
I've definitely been considering a smaller saw to keep on my tractor as well for getting branches and small trees. The 241 would fill that gap and compliment my existing collection. I really have no interest in farm grade or home owner saws. As they lack power to weight, and one would suspect long term durability.
I think I'm an addict as i would also love to add an MS880 to my collection for no other reason that it would be cool. The 660 takes whatever i cut with ease. I would never ever want to lug an MS880 around.
My old saw is a Sears saw from the early 1970's as I recall. My father bought it from his neighbor 25 years ago in the original (large) metal box, the saw was virtually new at that time, I doubt if it had an hour's time on it. Even had a newspaper from the early 70's in the box under the saw. Not sure who actually built them for Sears at the time. In the last 25 years I've owned it I probably average 1-2 hours run time a year tending to my 2 acres. I put a new replacement 21" bar and chain on it 15 years ago. I clean and oil the saw and sharpen the chain after every use, it's always ready to go. Never had a single problem with it, never fails to start and runs and cuts perfectly. Only problem is that it's getting heavier every year LOL, the handle and fore grip are solid mount not isolated like the new saws. I guess you could say I wanted more than needed a new saw, and buying the new 261 has re-energized me and makes me want to go out and cut something. LOL. Anyone know who built them for Sears at that time? I'll go out tomorrow and see if there are any markings on it. I guess I'll just put it up on the shelf and retire it, pitty, it's never failed me. thanks
Edit, while this is not an actual pic of my old saw, it think it looks just like this (only clean and with new bar, LOL). Found this picture on the internet, appears it's a Sears saw made in ~1970 manufactured by Roper, ~60 cc.. Heck, I'm almost 60 and I've never even heard of Roper ?? But it runs like a champ. I'll take a look at it tomorrow.
   / Stihl MS 261 C-M 18" vs 20" Bar #26
Anyone know who built them for Sears at that time? I'll go out tomorrow and see if there are any markings on it. I guess I'll just put it up on the shelf and retire it, pitty. thanks
I don't know anything about the older Sears saws, but I have an appreciation for the sound of the old time Homelite saws, back when they were serious saws. I still like to hear them run. Not so much to cut them them.
   / Stihl MS 261 C-M 18" vs 20" Bar #27
I would recommend against the 20" bar -- it makes the saw too nose heavy, and unbalanced (it won't even sit flat on a table with a 20" bar). The saw can pull a 20" bar in softwood, but not in hardwood, so it's of limited use anyhow. It'd stick with 16" or 18" bar. I have all three sizes for my 261, and 18" is the most versatile.
If you really need a 20" bar, I'd step up to a 60cc saw. In that size range, the Husky 562XP is the best option right now.
I have a fairly new 562XP (4.7HP) with 20" bar and it cuts through oak very quickly and easily. An awesome combination for me. I think a 20" bar is perfect for this saw in hardwood.
I Have an old Husqvarna 353 (3.2 HP) that had a 20" bar, which was at the max. of its recommended length and I was never satisfied with it. This is more of a 16" bar saw for limbing or the typical smaller stuff, which I will be using it for now as I have received the necessary 16" bar and four chains (my standard number).
I would think a 3.9 HP saw like the 261 would be in the middle, performance wise, and 18" may be a perfect, all around bar. All depending on what one is cutting.
   / Stihl MS 261 C-M 18" vs 20" Bar #28
Great saw that runs great with an 18" bar. It can probably handle a 20 but with a sharp chisel chain it will pull 18" at full speed. You'll love that saw.
Thanks everyone for the help, I'm confident I made the right choice. Hopefully the weather will cooperate this weekend and I'll get to test the MS261 out.
   / Stihl MS 261 C-M 18" vs 20" Bar #30
Anyone run any of the M-tronic Stihls side by side with a Carb Stihl? Same base model of course. Curious how much difference there is.
2019 Chevrolet Silverado 2500 4x4 Warner Service Truck (A55852)
2019 Chevrolet...
2025 IRET 13 Utility Electric Tricycle (A55853)
2025 IRET 13...
2019 CATERPILLAR 740GC OFF ROAD DUMP TRUCK (A52707)
2019 CATERPILLAR...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A55314)
2024 BCL...
FIAT ALLIS FD145 CRAWLER DOZER (A52707)
FIAT ALLIS FD145...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Forks...
