BX2360 rear hydraulics which lever controls which coupling
   / BX2360 rear hydraulics which lever controls which coupling #1
lamanated
Nova Scotia and Zephyrhills Fl
BX2360 JD 425 jd 455
just to ask which lever controls which outlet on the rear hyds? to save spraying on the floor to find out....thx
   / BX2360 rear hydraulics which lever controls which coupling #2
it won't spray out if you pull the lever
   / BX2360 rear hydraulics which lever controls which coupling #3
Left side outside lever controls which PTO(s) are engaged. Not sure if I am understanding the question.
   / BX2360 rear hydraulics which lever controls which coupling #4
Plug in the hoses, pull the lever, see what moves. :D
What are you needing the hydraulics for?
I adapted a New Holland plow blade onto the quick attach , so want to run the power angle off the rear hydraulics..
   / BX2360 rear hydraulics which lever controls which coupling #6
Yep, should work good for that.
With no hoses plugged in and the engine running, pull the lever, you will hear the engine slow and relief valve open. If there are exposed hoses or tubing going to the remotes that you can touch, you might feel some vibration with the valve open.
1998 FREIGHTLINER FL50 SPORT CHASSIS (A56129)
1998 FREIGHTLINER...
7021 (A55851)
7021 (A55851)
2021 Kubota RTV X900 4x4 Utility Cart (A55787)
2021 Kubota RTV...
1995 TALBERT 50 TON LOWBOY TRAILER (A58214)
1995 TALBERT 50...
2006 Cummins DGBB 35kW Standby Diesel Generator (A56857)
2006 Cummins DGBB...
John Deere 6ft (A56857)
John Deere 6ft...
