BX2360 rear hydraulics which lever controls which coupling
   / BX2360 rear hydraulics which lever controls which coupling #1
lamanated
Nova Scotia and Zephyrhills Fl
BX2360 JD 425 jd 455
just to ask which lever controls which outlet on the rear hyds? to save spraying on the floor to find out....thx
   / BX2360 rear hydraulics which lever controls which coupling #2
it won't spray out if you pull the lever
   / BX2360 rear hydraulics which lever controls which coupling #3
Left side outside lever controls which PTO(s) are engaged. Not sure if I am understanding the question.
   / BX2360 rear hydraulics which lever controls which coupling #4
Plug in the hoses, pull the lever, see what moves. :D
What are you needing the hydraulics for?
I adapted a New Holland plow blade onto the quick attach , so want to run the power angle off the rear hydraulics..
   / BX2360 rear hydraulics which lever controls which coupling #6
Yep, should work good for that.
With no hoses plugged in and the engine running, pull the lever, you will hear the engine slow and relief valve open. If there are exposed hoses or tubing going to the remotes that you can touch, you might feel some vibration with the valve open.
Bucket (A55973)
Bucket (A55973)
2014 F-150 STX (A56435)
2014 F-150 STX...
2019 GALYEAN...
LOT: (6) Ratcheting Chain Binders (A59076)
LOT: (6)...
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
2008 Sterling Acterra Ambulance (A56858)
2008 Sterling...
