Tire Pressure
/ Tire Pressure #1
Bluesteel
Gold Member
Illinois
LS MT 357HC
How much pressure are you running in your rear tires? I don't have any fluid yet but I noticed the tread or bars on rear tires are not fully contacting the ground. R4 industrial tires. I would think you would want the entire tread making contact. Thanks.
/ Tire Pressure #2
Here are a couple of ways to do this. #1) look in your Op Manual and see what the manufacturer recommends #2) Get your tractor on a very hard surface and inflate/deflate the rear tires until the entire width of the bars make full contact with the surface. Make sure both rears end up with the same pressure.
I run 18 pounds in my rears - its what Kubota recommends - it is the exact point where the bars make full ground contact. Strange - things seldom work out this way.
/ Tire Pressure #3
It depends if you are looking for more traction or less compaction. Less pressure and more contact probably won't change traction significantly if any but having more contact will lessen compaction.
/ Tire Pressure #4
20 lbs. That is what the manual recommends. They are loaded with Methanol/water mix. They are R4 43.16-20 tires.
/ Tire Pressure #5
My rears are loaded. I run 18-20 lb. pressure. Tires are R4's 43x16-20. I ran the same pressure before loading.
/ Tire Pressure
Thanks everyone for the replies. I'm going to set the pressure at 18lbs. I'll see how much they have in them from factory.
/ Tire Pressure
I checked pressure in both tires and they were dead on 18lbs. I didn't change anything even though all the tread isn't contacting the ground or in this case my garage floor. Doesn't spin or slip on the freezing rain and snow we just got. Was more concerned about uneven tire wear. Thanks to all who checked and replied.
/ Tire Pressure #8
Bluesteel;
Put ballast in your rear tires, you will not regret it. Windshield washer fluid, RV Anti-freeze, beet juice, etc. I use straight water here in S. Texas. We have the LS XR4046HC also and, as memory serves, about 40 gallons per rear tire to 75% full.
You'll think you have a different tractor.
Sent from my iPad using TractorByNet
/ Tire Pressure #9
I did not mention - my tires are loaded with Rim Guard. I have R1 - 16.9 x 28 rears that hold 69 gallons each or around 738 lbs per tire. You talk about increased traction - - there is no comparison between empty and filled. And adding fluid - rim guard(beet juice), RV antifreeze, regular antifreeze - does not place any added load on the rear axle either.
I would go empty rather than CaCl (salt) solution. CaCl solution is corrosive to everything it comes in contact with. I used it for 20+ years in my previous tractor and fought it dissolving the valve stems - annually. Dam, it was a mess!!! Don't use a salt solution.
You know, those R4 tires of yours may have a slight "wrap around" on the tread bars and the bars may NEVER make full contact with the ground - no matter how much air you let out.
/ Tire Pressure #10
Gustafson, why do you load your tires? What are the benefits?
/ Tire Pressure #11
Significantly improved traction and stability. The difference between tractor with and without loaded rear tires is like day and night.
/ Tire Pressure #12
I would have to agree with you, my bx doesn't have loaded tires, but I wish that it did. Just got the FEL for it a little over two months ago and I can already tell that i would love to have filled rear tires for using the FEL. But not so much for mowing with R-4's.
/ Tire Pressure #13
I think that heavy use of your new FEL will illuminate the need for loaded rear tires or, at very least, a ballast box on your 3-point. Wait until you try to pick up a big load with FEL and you raise one or both rear tires off of the ground. Did that once with previous Kubota B2710 that had unloaded R1's, trying to pull a root out of the ground with Chain on the FEL. Filled rears with water same day. Made no difference with mowing with both 72" MMM or 60" rotary cutter if that's your worry. Just way better stability and traction.
Good luck
2017 Ford F-150 Ext. Cab Pickup Truck (A61573)
2017 Ford F-150...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
UNUSED WOLVERINE HYD BRUSH CUTTER (A64281)
UNUSED WOLVERINE...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A61573)
2017 Ford F-150...
