What do you do with your forks?
   / What do you do with your forks? #121
Set newly painted diesel tank stand today with Titan 48" x 4000 lb. forks and Titan 72" extensions. EZ-PZ.
Sent from my iPad using TractorByNet
   / What do you do with your forks? #122
Ordered a set of Titan forks on Friday. This thread certainly helped with that decision. I've been waffling about what to get ever since I bought the tractor this past summer. Honestly should have spent the money way earlier, would have helped immensely with log stacking. Can't wait to remove the bucket and get the forks on!
Got to try out my forks today. I'm not sure exactly why this is, but there's a substantial gap between the bottom of my QA and the bottom of the plate on the forks. Tell me this is not normal, because they've already popped off while stacking a couple logs.
This pic was taken from the front of the tractor for reference.
That is way too much gap, it will allow the frame to slide up and come off the top of QA.
If it only comes off of one side it will likely bend the QA, as there have been many threads here on that problem.
Unfortunately Titan seems to have a history of this problem.
Read from this post on down: http://www.tractorbynet.com/forums/...ents-experience-2.html?highlight=#post3686514
   / What do you do with your forks? #123
That is way too much gap, it will allow the frame to slide up and come off the top of QA. <img src="http://www.tractorbynet.com/forums/files/attachments/406362-what-do-you-do-your-image-1435817224-jpg"/> If it only comes off of one side it will likely bend the QA, as there have been many threads here on that problem. Unfortunately Titan seems to have a history of this problem.
Our Titan 48" x 4000lb. forks fit very well on both of our tractors. New Holland TL100A has Bush 5045 FEL and the LS XR4046HC has the LS FEL. If the FEL QA is well seated in the Forks QA pockets the pins engage well thru the slots on the bottom of forks.
My experience with Titan Products has been exceptional! Your mileage may vary?
   / What do you do with your forks? #124
That is way too much gap, it will allow the frame to slide up and come off the top of QA. <img src="http://www.tractorbynet.com/forums/files/attachments/406362-what-do-you-do-your-image-1435817224-jpg"/> If it only comes off of one side it will likely bend the QA, as there have been many threads here on that problem. Unfortunately Titan seems to have a history of this problem. Read from this post on down: http://www.tractorbynet.com/forums/attachments/303512-titan-attachments-experience-2.html?highlight=#post3686514
Xfaxman, correct on all accounts. When it popped off the QA, it was from the bottom, though. That's how much gap there is. They bounce like crazy when going up my driveway. I'll take a look at the thread you supplied. Obviously will be calling Titan tomorrow as well.
   / What do you do with your forks? #125
Fwiw, the forks are extremely tight and difficult to slide on the frame. All in all, I'd say this hasn't been my favorite tractor related transaction.
   / What do you do with your forks? #126
I've used my Rankin pin-on forks to do something I think very few have done. For three decades I had a severe infestation of Canada thistle. If you have it on your property, you should appreciate this. Canada thistle has a vast network of underground offshoots. The average infestation contains many square miles of roots. As far as I know, it is the only thistle which spreads from pieces of its roots. In many states it is mandatory for property owners to eradicate it. It is one of the most destructive of the invasive weeds.
If you are considering an attempt to dig out this devil, it is imperative to not leave a single trace of viable root structure. Manual labor will not do the job, and may possibly contribute to the spread of the evil one. Knowing what I was up against, I decided to put my forks to a new use when I realized I could put them into the ground far enough to reach the tip of the root structure of the plant. Even the smallest of remnants is able to spread the infestation. Much of my time was spent combing through every clod of dirt which might contain a piece of a root.
I raised my loader high enough to insert the forks deeply into the ground. I had them spaced fairly close together. They are 42" long. With the forks pointing down, I pushed my joy stick all the way forward, lifting the tractor from the ground. The weight of the tractor was enough to force the forks deep enough, (24"-30") to reach near my goal, the bottom of the roots. Then, I used the curl feature to gently pull the soil and roots from the ground. This took quite a bit of time because I had to get off of the tractor every time I made a new excavation in my approx. 500 sf. area of invasion. When I bought my forks I never dreamed they'd be the one tool to help me conquer this nasty invader.
I hope I clearly explained this.
   / What do you do with your forks? #127
I haul my little diesel generator with them when I have to work on something away from the barn. I am careful to use my osha rated strap with knots in it.
   / What do you do with your forks? #128
If you stand beside fork, lift locking pin, and lift fork, a bit, with one hand and push top with other hand they move easily. You can put a bunch of grease on top rail but, that creates more problem than it solves.
   / What do you do with your forks? #130
I've used my Rankin pin-on forks to do something I think very few have done. For three decades I had a severe infestation of Canada thistle. If you have it on your property, you will be should appreciate this. Canada thistle has a vast network of underground offshoots. The average infestation contains many square miles of roots. As far as I know, it is the only thistle which spreads from pieces of its roots. In many states it is mandatory for property owners to eradicate it. It is one of the most destructive of the invasive weeds.
Nice, how large of an infestation did you have?
2006 Utility Trailer Trailer, VIN # 1UYVS13256P972701 (A53422)
2006 Utility...
1987 Ravens 45 ft. T/A Float Trailer (A53117)
1987 Ravens 45 ft...
Towable Light and tower (A55851)
Towable Light and...
2005 STERLING DAY CAB (A56138)
2005 STERLING DAY...
air compressor (A55758)
air compressor...
66in Bucket Skid Steer Attachment (A55851)
66in Bucket Skid...
