Ford 2000 or 3000
/ Ford 2000 or 3000 #1
Heidi1
Greece
Ford 3000
Hello guys,
I wasn't quite sure where to make my question, anyway...
I bought a ford 3000 as I told but I am not sure if it's this model or the 2000 one.
I am going to write the model's serial number in a row, I hope there arent numbers or letters missing, please help me if it's possible.
Serial number:
6G4B
G6 6
/ Ford 2000 or 3000 #2
How to find tractor serial numbers:
TractorData.com lists tractor serial numbers under the individual model. Use the menu at the left to select your tractor manufacturer and model, the serial number list will be on the tractor's data page.
How to read a tractor serial number list:
Tractor serial number lists nearly always show the first tractor built in each year. The other tractors for that year will have successively higher numbers. Your serial number should lie between two of the stated numbers.
Example serial number list:
Year
Number
1980
501
1981
879
<<< 900
1982
1034
1983
2103
Example: if your serial number is 900, then your tractor was built in 1981.
The list only shows the number from the first tractor built in each year. Unless you happen to have the first first tractor off the production line, then your particular number will not be on the list. Your number will lie between two listed numbers.
Deere 2640 tractor and engine serial numbersFind the REAL serial number
There are usually a lot of different numbers on a tractor. The engine, front axle, and cab may all have their own serial numbers. Various components may have parts or casting numbers. Make sure you have actually found the tractor serial number, and not one of these other numbers.
Model years versus calendar years
Tractors, just like automobiles, are manufactured on a model or production year. The new production year usually starts around September. A tractor built in October of 1955 would have been considered a "1956" model. Serial number lists almost always show the production year, not the actual calendar year the tractor was built. This information is generally more useful, because major changes would have been made to a model at the start of the production year, not on January 1.
Read the number carefully
On older tractors, the serial number plate has often faded. Make sure you do not confuse a 7 for a 1. Also, ensure you have read the entire number.
If the plate has faded very badly, try making a rubbing of the imprint. Place a piece of tissue paper over the plate and rub gently with charcoal or a pencil. Another method is to color the number with a marker and then quickly wipe it off, hoping to leave ink in the stamping. Some people have found that they can read the number off the back side of the plate
A serial number is not a tractor's life story
In general, you cannot determine anything but the year from the serial number of an older tractor. You cannot find the exact date of construction, original dealer, or previous owners. Your best chance at finding your tractor's history is to talk to the person you purchased it from. Find out who they bought it from. If you're lucky you may be able to trace it back to the original buyer and the original dealer. If you are really lucky, that dealer would still be around and have records of the sale. There are couple of exceptions...
/ Ford 2000 or 3000 #3
This link takes you to the basic information for a U.S. built 3000. Yours was built in Basildon U.K.
TractorData.com Ford 3000 tractor information
There should be another set of numbers on the pad, something that begins with 31NNNB or C1 and yours likely has a 6-speed transmission which was the standard for Basildon built 3000s surmising that yours was build July 4, 1966. Is it a Dexta or Super Dexta?
/ Ford 2000 or 3000
Hello and thanks for replying. Do you mean this serial?2015-01-10 17.25.35.jpg
I dont know if it is dexta or super dexta...the decals is from 3000. The transmission is 8 gear. 2015-01-10 17.34.24.jpg
/ Ford 2000 or 3000 #6
I don't see a 2000/3000 model I'd, post a tractor pic, including rear axle, also, check other side if belhousing, some Brit models have numbers there too. Underside of hood should have a foil tag too.
Post back
/ Ford 2000 or 3000 #7
It looks like a 3930 serial number and the production code would work for 1996.
/ Ford 2000 or 3000
Post back
here is some pictures of rear axle 2015-01-11 12.49.59.jpg 2015-01-11 12.50.41.jpg 2015-01-11 12.38.30.jpg
/ Ford 2000 or 3000 #9
Sheetmetal is correct for a 1966 2000/3000. Enclosed draft control spring and square rear axle housing points to it being a 3000. Would need complete correct model code to verify.
A 1996 3930 it is not. 96 would have two letters in the serial number.
/ Ford 2000 or 3000 #10
It certainly doesn't look like a 3930. 1996 was the first year they didn't have two letters in the serial number, but I missed that the location of the "B" is reversed.
1990: BC26239
1991: BC68791
1992: BD05932
1993: BD36207
1994: BD63909
1995: BD93327
1996: 021649B
1997: 056056B
1998: 083357B
1999: 111612B
/ Ford 2000 or 3000 #11
1990: BC26239
1991: BC68791
1992: BD05932
1993: BD36207
1994: BD63909
1995: BD93327
1996: 021649B
1997: 056056B
1998: 083357B
1999: 111612B
Noted.
/ Ford 2000 or 3000 #12
All of the part numbers on the castings are a 1965 design level. C5NN- is a 1965 Tractor Operations part number. So I'm going with Rick B that its most likely a 1966 Basildon built tractor. The Dexta/Super Dexta designations were dropped shortly after the introduction of the 2/3/4/5000 series in late 1964.
/ Ford 2000 or 3000 #13
square axle leads me to think 3000 as well.
I still havnt seen the ID number for either a 2000 or a 3000, so check that other side, or back further under paint onthe bellhousing.
/ Ford 2000 or 3000
Ford 3000 Super Dexta...This is the model.Finally i found it...thanks all for help!
2014 Caterpillar 304E Mini Excavator (A66734)
2014 Caterpillar...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
2018 Bobcat MT55 Ride Behind Track Loader Skid Steer (A66734)
2018 Bobcat MT55...
2015 KENWORTH T880 (A67714)
2015 KENWORTH T880...
2018 FORD F-150 (A67714)
2018 FORD F-150...
2009 IHI IC70-2 CRAWLER CARRIER (A65056)
2009 IHI IC70-2...
