yanmar ybh 760 backhoe attachment
/ yanmar ybh 760 backhoe attachment #1
Knifer
Winter Haven
Massey,JD 2010, International W6. '42 case
does anyone know where I can get replacement parts for it?
I need to put new seal in two of the cylinders.
I can't find any info on these on the web.
Any help would be greatly appreciated
/ yanmar ybh 760 backhoe attachment #2
I don't think you will find anyone selling seals just for the YBH 760, I think you will have to go to a hydraulic shop or a place such as this https://www.herculesus.com/ to get the seals. Most likely need to take the torn down cylinders with you.
Note these kits shown in the aboves on line sight. No idea they might fit yours but they are for Yanmar. https://www.herculesus.com/home.php?cat=50557
cool thanks I might just go ahead and buy 2 new cylinders
from the prices I see for parts I can go to Dalton hydraulics and get replacement ones for 120 dollars I think.
/ yanmar ybh 760 backhoe attachment #4
Hydraulic seals are universal. Just tear the cylinders down and take the seals to your local hydraulic shop to match by eye.
You need a huge pipe wrench to unscrew the end caps. Everything else is much simpler than you might expect.
Tip: leave one end of the cylinder secured to the BH so you have something to resist the unscrewing force.
I paid my local shop about $165 to do my first loader cylinder, and about $10 in parts for the next two that I did myself.
If you were considering buying replacement cylinders, you have nothing to lose by attempting repair of your existing ones first.
thanks good buddy
/ yanmar ybh 760 backhoe attachment #6
How old is the YBH 760? Maybe the company got bought out or something and the product got renamed?
There is a EA 760 Backhoe attachment.
There is a John Deere / Yanmar 760 backhoe attachment too.
https://for-sale.yakaz.com/john-deere-backhoe-attachment#lo=4&docid=000eeg3vsjq0g9ge
Is this your type?
/ yanmar ybh 760 backhoe attachment #7
Is this your type?
The 760 was sold by Yanmar dealers a little before and after 1980. I think it was intended for the larger Yanmars. Here's a prior thread accumulating what is known about the backhoes sold by Yanmar-USA back in the day. And I have a 1976 brochure listing a 'Brantley' backhoe, an earlier style sold about 1976.
I've seen the manufacturer of backhoes for Yanmar named in an old thread, but my research then led to the conclusion that they went out of business 30 years ago. Regardless, the components are all generic and overhaul parts are available at any hydraulic shop.
/ yanmar ybh 760 backhoe attachment #8
In a weird searching method, I found the 760 model being sold today as new over at Everything Attachement. The name of the company is Bradco.
Everything Attachments model 760 Backhoe It's a pricey little thing. For a mere $800 more, you get the PTO pump kit too.
Dug and found that the Brantley company was sold to American Equipment around the time Mr. Brantley died in 1993. Production and Manufacturing for OEMs, and Custom Equipment, Tractor Attachments and Backhoes amerequip.com They still make the backhoes and have parts even! The equipment is resold via the Bradco name to other distributors too.
/ yanmar ybh 760 backhoe attachment #9
Looking at the client listing, Yanmar still gets attachements from them too!
amerequip.com/client-list.html
/ yanmar ybh 760 backhoe attachment #10
If it helps a YBH750 was built by Woods. I have one and have sourced parts for it from Woods. Not saying a YBH 760 is Woods but you might want to post a picture so people can look at it. I agree with the others, for seals go to a hydraulic shop.
/ yanmar ybh 760 backhoe attachment #11
I have a 1984 336D with a YBH 750 and it is a woods.
JOe
/ yanmar ybh 760 backhoe attachment #12
JOe
That's good info. Seems the original manufacturing company got around supplying backhoes to many brand names. Thus, parts and ease to keep maintained would be plentiful.
/ yanmar ybh 760 backhoe attachment #13
I just noticed that the YBH-600, is the same as my Kubota L650. Don't know what yr., maybe late 70s-mid 80s?
/ yanmar ybh 760 backhoe attachment #14
Looks as if Mr. Brantley's company made these for just about every major CUT brand and implement brand out there.
" I had dug and found that the Brantley company was sold to American Equipment around the time Mr. Brantley died in 1993. Production and Manufacturing for OEMs, and Custom Equipment, Tractor Attachments and Backhoes amerequip.com They still make the backhoes and have parts even! The equipment is resold via the Bradco name to other distributors too."
/ yanmar ybh 760 backhoe attachment #15
Shovelrider, have you seen this thread discussing this model backhoe?
http://www.tractorbynet.com/forums/projects/126549-kubota-k-650-backhoe-rebuild.html
I put some links in that thread to more posts describing this model backhoe.
As for age: K-650 was originally sold with the Kubota L225, which I think was about 1980. Maybe somebody in the Kubota forum could name a precise year for that model.
I think L-650 is the same as K-650 but with all-new Kubota part numbers in its manual. Your photo of your L-650 looks identical to my (Kubota) K-650.
/ yanmar ybh 760 backhoe attachment #16
Thanks California, for the link. Very nice job myyaz33 did on his bh. Had lines made up at local auto parts store, I think around $128 for 9 of them. I've got about $2500 all total in mine. For me it don't have to look good, as long as no leaks, and everything works. When it dries up some around here it will get a work-out. Checked rear tire pressure today with bh attached (10)psi, added 10 more psi. Its seems to sit better and still ride ok. Running the 8.3-24s, would like to get R1s to fit rims. But not sure of options that will fit, something that won't have the wife on my case about her yard. LOL. Would like widest that will fit, running brand new w/tubes on front Deestones 5.30-12s 1050lbs@80psi. Only have 4'fel, so something w/ratio that'll match. Anyways thanks again for everybodys advise, and I am still working on sub-frame for bh, rather than spending the $$.
/ yanmar ybh 760 backhoe attachment #17
Search for your next JOBS
Is this your type?
Was at the neighbors down the road today. They showed me their Yanmar YBH-660. They run it off of a Ford 8N. Looks like the images posted in this thread. All read and such.
/ yanmar ybh 760 backhoe attachment #18
Minor update to the Yanmar backhoe 'common knowledge': ARPS was the American (Canadian?) company providing backhoes to both Yanmar and Kubota to sell as OEM in the early years, mid 70's into the 80's.
When I went looking for a bucket tooth, it turned out to be unique but the tooth manufacturer said buy it retail from a Deere dealer.
Deere had a small hoe at the time that looks identical except swing-out stabilizers in place of the vertical plungers on Yanmar YBH-600 and Kubota K650/L650. Looks to me that ARPS built that 'Deere' hoe too.
I think ARPS later merged into some other company.
/ yanmar ybh 760 backhoe attachment #19
The odd thing about these YBH modes, there is no Yanmar logo on them. Just a printed block letter text of YANMAR 660. Just like the other image I had shared in 2015. Weird really.
