Dash Board on the B Series
/ Dash Board on the B Series #1
Al Mac
Canada
Kubota 2920
My B 2920 has a easy to read dash board in the daytime. At night the needles don't go out far enough to see them in the lighted background on the outer edge.
Is this just me or is this a issue with the B series (not sure about other units) and has a fix already been put in place.
Al
/ Dash Board on the B Series #2
My 2620 does the same thing. I rarely use the dash lights as the headlight system leaves a bit to be desired. I instead rely on the two led lights I have mounted on the rops to look at the gauges. I agree that Kubota should have designed a better system for the dash lights.
/ Dash Board on the B Series #3
Interesting. I haven't tried running our B2320 at night, yet.
I'll have to check. Would make snow blowing in the dark kind of a guessing game.
If ours is the same, I think I'm going to see if I can put an LED somewhere in front of the dash to illuminate those gages. Maybe on the top of the steering column, with a shield, so the (LED/bulb) isn't visible from the seat.
I'd really like to know if the engine's about to overheat or run out of fuel, long before it does so.
/ Dash Board on the B Series #4
I haven't really noticed that problem. I've got about 260 hrs on my B3300. I know when I head out if I have enough fuel for what I'm doing and despite trying, I've never got temp above normal, even with the grill all but blocked from chaff while bushhoging
/ Dash Board on the B Series #5
Interesting point....My B2650 gets used frequently in the dark but I always use the Cab mounted work lights front and back and never switch the tractor lights at the front of the hood on so don'tknow what my dash looks like at night. I use it for snowblowing and the tractor lights reflect off the snow blower (front mounted) particularly when the snow builds up and causes glare. Next time I'll switch on the lights just to see what the dash looks like at night..It's a digital display...no analog gauges.
/ Dash Board on the B Series #6
I have to look for that next time. I snowblow all the time in the dark and have not had any problem reading my gauges.
I have no cab and just a work light the dealer installed on the ROPS (facing back). I noticed this when blowing snow in the evening as I work all day. I always have lots of fuel and the RPM will max out but it is the temp that I want to keep a eye on.
Would like it better and thought this was the best place to ask.
/ Dash Board on the B Series #8
I can understand wanting to keep an eye on things but do you have reason to suspect overheating? I'm more concerned that mine is running to cold rather than overheating
/ Dash Board on the B Series #9
The 2650 gauge cluster is back lit and digital so it's easy to read all the time, day or night. It's lit whether the headlights are on or not. I have no complaints on the gauges. I use my tractor a fair amount in the dark in the winter moving snow, as I leave for work in the morning while it's dark, and don't get home until after dark.
/ Dash Board on the B Series #10
Right you are.....Duh!...I checked this afternoon and as you say it lights up when the key is in 'run' position. I've been seeing it all along....Must be age creeping up on me.
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
2019 Kenworth T880 Tri-Axle Dump Truck (A61573)
2019 Kenworth T880...
KBH Tender (A63688)
KBH Tender (A63688)
2019 Peterbilt 567 Quint Dump (A62613)
2019 Peterbilt 567...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
2013 Hyundai Volster Coupe (A59231)
2013 Hyundai...
