2030 hydraulic leak
/ 2030 hydraulic leak #1
jacob59
Tebbetts, Mo.
LS 2030, 9N, Ford 4600,
I posted earlier about a slight hydraulic leak dripping from the left side of the rear end. I thought it was coming from a loose case bolt but it continued to leak. I couldn't locate it so I took it to the dealer. They seem to think its seeping from the case but want to
pressure test it before they split it and reseal. Now I've been without this tractor going on 2 weeks.Tractor has only 25 hrs on it.
Need to plow my garden. Wish I had my 9N.
Turned out the rear case is seeping hydraulic oil under pressure. Dealer says there assembled with a silicone seal. They have been very helpful. I, m going to pick up my tractor tomorrow plow the garden and have them repair it next month. They offered to drop it off for me but there just up the road so I, l'll get it. 5 year warranty is a good thing.
/ 2030 hydraulic leak #3
Just discovered similar issue on my J2030 with 42 hours on the meter. Dealer is going to pick it up and try to find the leak (somewhere in the hydro area). I thought it was a simple filter seal but they sent a tech out and he says it has to go in to the shop-- doesn't sound good except that I won't have any out of pocket costs-- just have to figure how to keep my 850' driveway clear of snow for a week or so. Harder than you think since I live just south of Lake Ontario so we get a lot of lake effect stuff.
I'm going to give my dealer a heads up on your issue- may save him some time- Thanks
Hey PVH. I haven't taken the tractor back yet for repair but I will let you know how it goes when I do. The leak I have is a very slight one but its still a leak. Let me know how it turns out. They may have to split the case.
How does your tractor fair pushing snow or do you blade it.
Thks Jacob.
/ 2030 hydraulic leak #5
Thks Jacob.
Sounds like your leak and mine are very similar- supposed to get a call about when they will pic it up to fix- stay tuned-
BTW I "blow" snow
Nice set up. Beats a shovel.
Jacob
/ 2030 hydraulic leak #7
Heads up--Just got the word- My leak results in my dealer having to tear apart and reseal MY entire hydro tranny... thank God no LS parts as dealer says it takes them a week to get any part... so I should have my baby back by Monday..your info was helpful- pointed my dealer in right direction.
Thanks for the reply. I haven't taken mine in yet to be repaired but I would be intrested in hearing on how yours turns out and where and how the seal failed. Also how long it took to fix.
Thks Jack
/ 2030 hydraulic leak #9
Just got a call they are bringing my tractor back this PM. Took them two full days to split the case and reseal. I asked they service guy about the issue and if it was unique or not- He told me it's the third one they've done on this same model- and they said they were done a while ago and owners have not reported a return of the same issue. I guess the LS folks are aware now that there was a defect in the assembly process. Shouldn't cost you a dime and it should take two days- hope it works out for you.
Thks again. Merry Xmas!
Jack
/ 2030 hydraulic leak #11
:eek: Just sent my J2030H back to deer-- still leaking.... they are embarrassed... I'm am beginning to get concerned. stay tuned. Phil
Thks fot the update even though its dissipointing. Good luck.
Jack
/ 2030 hydraulic leak #13
Spoke with service manager re: leak- He said it was a fitting that wasn't tightened properly- they are in process of running (testing) tractor to insure that they have resolved issue. I'm hoping they have- will know more in a day or so.
I'm curious if it turns out to be a loose fitting, where its location is and if its a supply line, a retutn line or a psi switch connection.Thks again. Jack
/ 2030 hydraulic leak #15
Well they picked up my tractor for the third time today- I expect that they will take a bit more time looking for the leak this time. Will post with findings when I hear. Happy New Year......I guess....
/ 2030 hydraulic leak #16
I would think they will get it right on the third try!!!! :pullinghair:
/ 2030 hydraulic leak #18
Well finally got the leak sorted out- there were two leaks actually. first one was a hydro line that needed another half turn to seal. The second was coming from my loader valve quick disconnects- I had two of them that were leaking- both replaced under warranty and no more leaks- hope this helps another forum member avoid being frustrated to edge of looney bin..
What about the leak from the tranny case. Did they split that for nothing or was it leaking also.
Thanks Jack
/ 2030 hydraulic leak #20
Thanks Jack
Yeah they split the case to fix the third leak- they got that one the first time the tractor was in.
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
2025 IREAS Grid-Shaped Rock Bucket Mini Excavator Attachment (A61572)
2025 IREAS...
Tan Jet Dock Drive-On (A59228)
Tan Jet Dock...
14in Digging Tooth Bucket Excavator Attachment (A64194)
14in Digging Tooth...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
