farmall super A distributor shaft issues
   / farmall super A distributor shaft issues
My farmall super a distributor shift will not turn as engine is rotated. Distributor gear is in good condition. Removed housing distributor fits into and no issue, all gears move freely. Could there be a problem inside the front engine cover (I think this would have the timing gears inside). The service manual is vague in this area. Any suggestions?
   / farmall super A distributor shaft issues #3
Sounds like it may be the distributor drive shaft. This would be part #9, in this exploded view of the distributor drive system. Object moved
Well, the link did not carry through completely. So, click on electrical system in the menu. Then click on the second item that appears in the next menu, (094). On the next page, the distributor drive will appear in an exploded view. Look for # 9.
You'll need to pull the governor assy. off to check and see if that is the problem.
   / farmall super A distributor shaft issues #4
By the way, don't panic on the price, if that is the problem. Here is the part number 353934R11, or you can copy and paste the number to a search engine. I have the best results with Google when searching for parts.
A quick check on Google shows more than several for between $25 & $30.
I'm thinking part#9 connects to the governor. I think something is broke inside. Know of any good picture diagrams of the governor internals. Thanks for the info.
   / farmall super A distributor shaft issues #6
Hopefully this link directly from the Case/IH online parts store will work. Official Case IH Online Parts Store and Case IH Catalog for Best Parts Search and Best Parts Look Up. Case IH Parts for Case IH Tractors, Case IH Combines, Case IH Tractors, Case IH Manuals, Case IH Parts Here is an exploded view of the governor internals. The tangs on the drive shaft engage in the slots in the back of the pinion gear (#28). The drive shaft, and the pin that holds the dist. gear on the dist shaft, are the two weakest links in that drive.
Thanks for the info, I'll start working at it the next few months. I'll let u know what I find.
   / farmall super A distributor shaft issues #8
G'day is the camshaft turning? You may have a broken timing chain/gear
Jon
   / farmall super A distributor shaft issues #9
WE have found issues with the drives from time to time that we could not explain for the load on it. Then again most are over 50 years old with materials that go back over 60 years.
1611 (A57192)
1611 (A57192)
2015 Chevrolet Silverado 3500HD Knapheide Enclosed Service Truck (A56858)
2015 Chevrolet...
New/Unused Quick Attach Pallet Forks (A57454)
New/Unused Quick...
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
Unused IRTPL 10,000lb Two Post Car Lift (A55272)
Unused IRTPL...
Hercules Safe (A57149)
