leaking coolant from water pump area
/ leaking coolant from water pump area #1
motownbrowne
Elite Member
river falls, wi
Kubota mx4700 HST, New Holland TC-29D
First off, my mx4700 has been an incredible machine so far. Amazing how much more capable it is than our 8ns!
Today I went to fire it up after 2 hours on the block heater of course. Noticed some coolant in the snow under the front axle. I checked the hoses, no leaks.
Upon closer inspection, there's coolant leaking from the front of what I'd call the water pump housing. Not from the pump shaft itself, not even from the seal between what I'm (perhaps incorrectly) calling the housing there's several bolts that go into the block and one nut that looks to be threaded onto a stud protruding from the block. The coolant seems to be slowly leaking from the one nut on the stud.
Any ideas? Try tightening it up? Call the dealer? I'm still under warranty, but this seems like it might be a super simple fix.
Thanks in advance for the help.
/ leaking coolant from water pump area #2
I experienced a leak on a straight-6 1967 Olds--my first car. There was a valve at the bottom of the water pump where anti-freeze was leaking from. Sounds to me like the pump has to be pulled and the gasket resealed. And if you have over 1,000 hours on the tractor, you probably should replace the pump while you are at it.
Good luck.
Actually just under 100 hours on the machine. Like I said earlier, the seal doesn't seem to be leaking, the coolant seems to be coming from around one of the fasteners. Any suggestions? Tighten it up, or call the guys at the dealership and see what they say?
/ leaking coolant from water pump area #4
It sounds unusual and a very rare failure. I'm assuming you have fully verified that the leak is from the immediate area of the bolt...not running down from somewhere higher. Since it is still in warranty, I'd let the dealer handle it. If you just tighten things up and a problem occurs later you might not notice and a larger problem could arise. It should not be leaking..this isn't like a lug nut that should be checked for torque after a few hours of initial operation. If the gasket is bad, it should be replaced.
/ leaking coolant from water pump area #5
With only 100 hours, I too would vote for contacting the dealer. It wouldn't take much torqueing to strip one of the bolts retaining the pump housing. I'm thinking that someone was a little stingy in applying gasket cement at the factory. Either that or they tore the gasket before assembly.
I would make sure that the dealer doesn't try and fix the situation by simply laying a bead of silicon around the effected area. Inspect the area before and after his work.
/ leaking coolant from water pump area #6
Here is what the inside of your pump looks like....
Could be the seal in the pump leaking.
Thanks for the photo! That definitely helps. I'll check it out further when I get home from breakfast, but I think it is leaking from the smaller hole between the two "chambers" on the housing.
Thanks for the advice everyone. I was kinda thinking that calling the dealer might be the way to go, but wanted to make sure that it wasn't something people had encountered before.
/ leaking coolant from water pump area #8
The fan often moves anti-freeze with a leak so it can be deceiving as to where the leak may be from.
/ leaking coolant from water pump area #9
At first I thought it might be coming from the 'weep' hole in the front part of pump area, where the shaft in located. I agree with previous posters, under warranty, take it to the dealer. Part of the deal when you bought a new tractor,, let them fix it.
Checked it out again today. It's coming from one of the fasteners on the perimeter of the housing, or at least that's where I saw it yesterday. No sign of any coolant on the frame, front axle, snow, or water pump, which is where it was yesterday. Guess I'll keep a close eye on it over the next couple weeks and schedule a service if need be. Thanks for the assistance.
/ leaking coolant from water pump area #11
Mine also leaks a few drops whenever the block heater is plugged in otherwise it never does. Been that way since I bought it in 2007, but unlike you the heater was installed by the previous owner , not the dealership and of course mine has been out of warranty for ages.
I plug it in maybe 5 times a year at most and I can spare a few milliliters of coolant lol, I stopped worrying about it long ago.
Interesting. This is only the second time I've used the block heater. Last year I noticed some coolant leaking also, about the same time of year; it could even have been the other time I used the heater. That time I found the source to be a loose hose clamp on the top radiator hose. I understand that the heater could increase coolant pressure, but why doesn't it go into the reservoir instead of forcing it's way out?
/ leaking coolant from water pump area #13
Nope, heater has nothing to do with a rise in pressure, as a matter of fact, it will reduce pressure by 'cooling" the coolant. The block heater will give a rise in pressure because it's heating the coolant, should still not leak, though. My guess is that the gasket has broken away some how, maybe just a re-tight of the nut, maybe a take out and application of silicone will do the trick, but if it's still under warranty, I wouldn't touch it, you could snap the casing by over torquing, let them handle it.
When I said "heater" I meant block heater. That's the only kind I got. Wish I had a heated cab, but I'd say that's at least 10 years off.
/ leaking coolant from water pump area #15
Gottchya, :thumbsup:
/ leaking coolant from water pump area #16
Replaced water pump last year and if i remember correctly one our two of those bolts thread into water passage. Is it possible someone forgot the thread sealer on those bolts? If that is the case just have to remove install the sealer and re-torque. Steve
2013 DODGE RAM 2500 CREW CAB TRUCK (A64280)
2013 DODGE RAM...
New/Unused AGT 3000PSI Hot Water Pressure Washer (A65583)
New/Unused AGT...
Landhonor SAD-12-23C Skid Steer Mount Auger (A62679)
Landhonor...
2010 PETERBILT 384 (A65643)
2010 PETERBILT 384...
John Deere 4044R (A62177)
John Deere 4044R...
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
