Backhoe Ripper
/ Backhoe Ripper #1
LD1
Epic Contributor
Central Ohio
Kubota MX5100
Thought I'd share some pics of a ripper I threw together a few days ago.
Was needing something to start removing trees from around the pond and clearing a fence row. I only had a 2' and 3' bucket and those make a big mess trying to remove 6"-12" trees.
IT was just made with scraps. So nothing fancy. Its all 1/2" metal, and about 28" long. I was worried about the 1/2" metal for the mount where it attaches to the boom, but using it for a few hours yesterday, it looks like it will hold up to whatever my backhoe can dish out.
/ Backhoe Ripper
Here are some pics of the carnage from about 3 hours of play
IMG_20141229_142021_287.jpgIMG_20141229_142027_131.jpgIMG_20141229_153422_241.jpgIMG_20141229_153451_971.jpgIMG_20141229_153520_755.jpgIMG_20141229_153548_578.jpg
/ Backhoe Ripper #3
Looks like it works fine. I'll probably be looking to do something like that in the future. It appears the cutting edge is just squared off. Is there a reason you didn't grind it a bit and give it more of a "V" shape to assist in cutting roots?
/ Backhoe Ripper #4
Nice, I like it.
/ Backhoe Ripper
There are a few reasons I didnt "sharpen" it. But knowing that I always could later if needed.
Time consuming.
It would likely just dull quickly anyway.
Alot of the rippers I saw when gathering ideas were not sharpened either. Rather the ones I liked had teeth to help grip and pull. This one doesnt have alot of teeth, but left a step in the metal (was already there, remember scraps), them welded a piece on the bottom to also catch and rip stuff.
And likely the main reason I didnt, is cause I didnt want to slice through the roots. Since this is a pond bank, that will likely be getting reworked in the near future, I wanted to pull/rip as many of them out of the ground as possible, instead of just slicing them and leaving them in the ground.
/ Backhoe Ripper
Did you laminate a couple layers of the 1/2" together for the shank?
yep. 2 pieces. touching in the front. and spaced by a piece of 1-1/2" steel at the back to make it more wedge shaped. And by design it wasnt really to make it like a wedge, but to gain some thickness so it had more side-to-side strength and not just bend over.
/ Backhoe Ripper #8
Thanks. I can definitely appreciate the "build with what ya got" approach. I need to make one for my BH77
/ Backhoe Ripper
Probably not needed to build as heavy or big as this. I am using this on my 18000# machine and haven't hurt it yet. For a BH77, I'd probably just use a single 1/2" piece, and maybe 18" long
/ Backhoe Ripper #10
LD1, do you have a thumb on the hoe? If not, add one, thet are a must for brush and limbs.
2008 Toyota Camry Sedan (A61574)
2008 Toyota Camry...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
New/Unused...
2017 CATERPILLAR 950GC WHEEL LOADER (A64279)
2017 CATERPILLAR...
2023 Deere 325G (A60462)
2023 Deere 325G...
2022 EZ-GO ELITE...
