Backhoe Ripper
/ Backhoe Ripper #1
LD1
Epic Contributor
Central Ohio
Kubota MX5100
Thought I'd share some pics of a ripper I threw together a few days ago.
Was needing something to start removing trees from around the pond and clearing a fence row. I only had a 2' and 3' bucket and those make a big mess trying to remove 6"-12" trees.
IT was just made with scraps. So nothing fancy. Its all 1/2" metal, and about 28" long. I was worried about the 1/2" metal for the mount where it attaches to the boom, but using it for a few hours yesterday, it looks like it will hold up to whatever my backhoe can dish out.
/ Backhoe Ripper
Here are some pics of the carnage from about 3 hours of play
IMG_20141229_142021_287.jpgIMG_20141229_142027_131.jpgIMG_20141229_153422_241.jpgIMG_20141229_153451_971.jpgIMG_20141229_153520_755.jpgIMG_20141229_153548_578.jpg
/ Backhoe Ripper #3
Looks like it works fine. I'll probably be looking to do something like that in the future. It appears the cutting edge is just squared off. Is there a reason you didn't grind it a bit and give it more of a "V" shape to assist in cutting roots?
/ Backhoe Ripper #4
Nice, I like it.
/ Backhoe Ripper
There are a few reasons I didnt "sharpen" it. But knowing that I always could later if needed.
Time consuming.
It would likely just dull quickly anyway.
Alot of the rippers I saw when gathering ideas were not sharpened either. Rather the ones I liked had teeth to help grip and pull. This one doesnt have alot of teeth, but left a step in the metal (was already there, remember scraps), them welded a piece on the bottom to also catch and rip stuff.
And likely the main reason I didnt, is cause I didnt want to slice through the roots. Since this is a pond bank, that will likely be getting reworked in the near future, I wanted to pull/rip as many of them out of the ground as possible, instead of just slicing them and leaving them in the ground.
/ Backhoe Ripper
Did you laminate a couple layers of the 1/2" together for the shank?
yep. 2 pieces. touching in the front. and spaced by a piece of 1-1/2" steel at the back to make it more wedge shaped. And by design it wasnt really to make it like a wedge, but to gain some thickness so it had more side-to-side strength and not just bend over.
/ Backhoe Ripper #8
Thanks. I can definitely appreciate the "build with what ya got" approach. I need to make one for my BH77
/ Backhoe Ripper
Probably not needed to build as heavy or big as this. I am using this on my 18000# machine and haven't hurt it yet. For a BH77, I'd probably just use a single 1/2" piece, and maybe 18" long
/ Backhoe Ripper #10
LD1, do you have a thumb on the hoe? If not, add one, thet are a must for brush and limbs.
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
8" Mini Excavator Bucket (A66285)
8" Mini Excavator...
Butler MFG Water Tanker (A63688)
Butler MFG Water...
Landhonor Mini Skid Steer Quick Attach Grapple Bucket (A66285)
Landhonor Mini...
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
2006 Mack Granite CV713 Dumping Flatbed (A62679)
2006 Mack Granite...
