where do you store your tractor - inside or out?
   / where do you store your tractor - inside or out? #31
I have a 35 by 14 insulated storage building designed to hold a car/tractor, but that would crowd me and my projects. So I build a 35 by 10 shed beside it with a gravel floor for the tractor and lawn tractors. Works great. Just had to go high enough to clear the ROPS.
   / where do you store your tractor - inside or out? #32
I'd keep them next to my bed, but the floor won't support the weight of 2 large frame Kubota's so they stay in the barn.......
   / where do you store your tractor - inside or out? #33
Tractor kept in the barn.
Today, the tractor was joined by the implements. I just completed the demolition of the old horse stalls that prevented full use of the barn for all things tractor!
Happy day!
   / where do you store your tractor - inside or out? #34
My BX2370 is outside plugged in and under a tarp. I was that I could atleast put it inside of a carport.
   / where do you store your tractor - inside or out? #35
Outside on patio but under deck with aluminum roofing to shed water so she stays nice and dry and close to house. Battery tender hooked up with an easy disconnect. Would love to have a little shed/barn with power and fully enclosed but that project is down low on the list.
   / where do you store your tractor - inside or out? #37
In the barn, always!
   / where do you store your tractor - inside or out? #38
All our equipment stays in the barn. As soon as the job is done they go back in. I have a 2001 New Holland that has never sat in the rain since I bought it new.
   / where do you store your tractor - inside or out? #39
Barn or shed, anything to keep the elements somewhat at bay. Unheated, unfortunately.
   / where do you store your tractor - inside or out? #40
Yep... in the new year I might actually try to heat my shop with some hard plumbing rather than portable heaters! My rule is to keep it covered whatever it is. Sides preferred but at least a roof!
2017 Ford F-150 Ext. Cab Pickup Truck (A55973)
2017 Ford F-150...
Krause Dominator 4850-18ft (A56435)
Krause Dominator...
TEST YOUR BID BUTTON! (A58375)
TEST YOUR BID...
GAME FISHER 5HP OUTBOARD MOTOR (A58374)
GAME FISHER 5HP...
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
2011 DODGE RAM (A56858)
2011 DODGE RAM...
