Picked up a new "accessory" for the tractor
   / Picked up a new "accessory" for the tractor #1
TSO
Elite Member
SouthEast Michigan
Massey 1652 HST Cab
So I've been looking for a nice set of MATCHING wheel weights for quite awhile. Finding the right size had been a challenge, and dealerships that claimed to have used weights (new ones are pricey) still wanted $1.00 per pound, if they had matching sets at all. So finally found a guy within a reasonable drive that had a matching set of 4 weights! These are some nice old IH weights that they used on their farm. Said they got them from someone else years ago. So it's kinda neat to think these weights probably have interesting stories to tell. I weighed them, and they each weigh 135 lbs, so 270 lbs per side, and 540 total. Ended up paying $300, which works out to be about $0.56/lb - seems like a very fair price (thoughts?)
Anyhow, they needed to be cleaned up and sanded (lots of rust but excellent condition overall). Spent about 30+ mins on each one just getting them prepped for paint. Well the paint finally cured and KenB2920 (thanks again) stopped by and helped get them mounted last night. I was torn on whether to paint them black, gray, or red... obviously went with the red, and I'm not 100% sure I like the color - what do you guys think?
PICS:
   / Picked up a new "accessory" for the tractor #2
Nice find, I vote for black myself.
   / Picked up a new "accessory" for the tractor #3
I'm with Murph. Same color as the chassis of your tractor.
Weights are hard to find here also. Especially something that will bolt on. Friend gave me a pair of old JD weights last year. I had to make a mounting bracket to fasten them to the Kubota.
At farm sales weights usually bring .25 p/lb. Higher if they are a commonly used weight. Rarely .50 p/lb.
   / Picked up a new "accessory" for the tractor #4
Another vote to match the frame color, black?
   / Picked up a new "accessory" for the tractor #5
I like the red but I have no idea what the correct color is.
   / Picked up a new "accessory" for the tractor #6
Why are they mounted backwards ? Is that the only way they would fit ?
   / Picked up a new "accessory" for the tractor #8
Weights are shaped like that so they will bolt on either side of the cupped disc. Depending on what track width setting the owner wants, he might have the center discs turned the other way, cupped in rather than out. In that case the weights would be bolted on the opposite way.
   / Picked up a new "accessory" for the tractor #9
If you had bought them from Massey for your tractor, they would be black. ;)
   / Picked up a new "accessory" for the tractor #10
TSO was told they were IH weights. I've not saw any IH weights like those. Maybe for the smaller/newer models?? Certainly not from an old M or H. Not from a newer/larger 1056, etc. Not sure what they would have been on?? Then again, maybe the previous owner had them on an IH so called them IH weights?? Hafta call them Massey weights now. :)
New/Unused 13ft X 20ft Single Garage Metal Shed (A57454)
New/Unused 13ft X...
LOT: Dewalt Electric Sawzall, Craftsman Palm Sander (A59076)
LOT: Dewalt...
LOT: (40 approx. ) Chain Link Fence Panels (A59076)
LOT: (40 approx. )...
16ft T/A Flatbed Trailer (A56858)
16ft T/A Flatbed...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
72in Forklift Safety Basket (A56857)
72in Forklift...
