My snowplow adaptation
/ My snowplow adaptation #1
mikehaugen
Elite Member
Lee, IL
John Deere 1070
So a little back-story... A guy a work with offered me an old truck plow for a great price about 7 years ago but at the time I was not interested. A few years later (about 5 years ago) I got my tractor and became interested in the plow and asked if I could still get it. "Sure, i just have to un-bury it from behind the shed." It has taken that long for this to happen, so I picked up last weekend, and spend last week and this weekend building my mount. It is a 7 1/2' meyer plow.
Here is the mounting bar sitting under the tractor while I figure out the rest of the brackets.
Here is the front bracket that will support the weight of the plow, I am also mocking up the lift arm and cylinder. There were some empty mounting holes there that I assume are for mounting front attachments like a snowblower or power brush. I am trying to keep the lifting mechanism as narrow as possible to be able to still keep as many front weights attached as I can. I think I will only have to remove 2, so I will still have 6.
The mounting ears for the cylinder
Here is the finished front half of the hanging brackets
This is a close-up of the mounting for the front lift assembly.
Here you can see the rear braces that go back to the center of the tractor. It hangs from the bottom of the loader brackets, for some reason reason there is a spot with holes, it made a convenient place to mount this. These braces should hopefully support any thrust loads from pushing snow.
A close-up of the pivot for the lifting arm.
Here it is mounted and for testing.
I wanted to check for clearances and flex and wanted to see how my my lights work. Everything clears nicely and there is no visible flex while raising the plow. I found out that I definitely need to make some light towers for auxiliary lighting. I think I will try the TUFF light led's.
I will have to remove the mount again and paint it. I also have to figure out hose routing. I am using the loader ports for lift and tilt, so I can use my loader joystick. In case anyone is wondering, I used all 2"x2"x1/4" square tubing and 1/2" plate.
Nice work! Should serve you well.
Thanks, I hope so.
I do have a question for you guys though. I want to get feet for the plow since I will only be plowing gravel, but I measured some aftermarket feet that are supposedly for this plow (bwcause that's what i could find lically) and the minimum height is 3 1/2"... that puts my blade about 1 1/2" off the ground. Isn't that a bit too high? The wear strip is 5 1/4" so I assume it's been worn 3/4" of an inch. Does anyone know if the oem meyer feet are any shorter? This is an st90 and uses the ski-type runners.
/ My snowplow adaptation #4
Never been a fan of the Meyer feet, have a tendency to dig in when you back blade. Like the ones, which are basically a bowel with a rod in the center.
Thanks for the advice. I was kind of thinking that. I may buy that type and modifying them to work. I need 1 1/4" shank, the "mushroom" type ones I see are smaller diameter but I could cut the shank off and weld on some 1 1/4" round stock. I can't think of an easy way to duplicate that shape so it would be easier to buy and modify.
/ My snowplow adaptation #6
Meyer feet aren't worth a **** , find the round ones off a western . Try angelos plow parts on line .
/ My snowplow adaptation #8
Bush it, put a zerk in it and weld the bushing in. We wear out a set of feet every year, adapating feet gets to be a pain. Also, on the Meyer plow the pivet for the trip, needs a zerk and grease. They are know for rusting and snapping off right there, no big deal to do now.
/ My snowplow adaptation #9
I bought mine at Tractor Supply, the round ones.
Here's the lightbar I made... not sure why it's sideways.
Here it is getting ready for clean-up/paint.
So I thought I would give this a try for the feet. It's 5" round stock 1-1/2" long with about 1/2" 45 degree chamfer. Not sure if I chamfered it enough, but we'll see.
/ My snowplow adaptation #14
I know this is brought up in about every plow adapt thread........but.......
id you add a crossover valve?
I see you used the SA cylinders. So adding one is cake, and not too expensive.
I cannot comment on the feet. I dont use them.
I knew that was coming! :laughing:
No I did not, but I plan to eventually. I thought I was in a bigger hurry, but it just doesn't seem like we are getting snow this year. I'm still in trial mode to see if there are any changes I want to make. I'll just have to be careful for now.
/ My snowplow adaptation #16
Yep, be careful. Not likely you will damage anything other than hoses. But for $50-$60 to do it right, why not.
/ My snowplow adaptation #17
I don't have feet or a crossover valve now, but growing up our plow had the mushroom feet mounted on a slight angle so they would spin when they started to drag instead of wearing in one spot.
/ My snowplow adaptation #18
Nice adapting fab!! Looks like you are getting ready for some action!
I used to plow with an older Fisher 7.5 feet plow. (it is one of my upcoming projects to take it off the truck, and install it on my UTB 643DT) Trip edge is wayyyyy better than the tilt action (soft) of the mold board on the Myer brand. You will loose a lot of snow everytime you hit something hard. For the feet, I do find 1.5 inches a little high. But for your first snow, that all good. It will be more for the subsequent pushes. The round feet from Fisher , work reel nice, and were easy to adjust, using space washers to get increments by 1/4". The cross-over valve could prove to be a life saver, as already suggested.
Also I don't know how low your directional cylinders are, but for truck mount, the Meyer one were sitting so low that they regularily took unwanted beetings; so keep a close eye on them when you will get out the first few times.
Keep the pics coming!! And hopefully action clips to follow:)
Happy Tractoring!
Got it painted and just finished reinstalling it.
Here is a close up of the feet installed.
The edge is 1-1/4 off the ground... we'll see how it goes. Maybe over the summer I will take the plow apart and have it blasted then paint it. I will also probably install the crossover relief at that time.
/ My snowplow adaptation #20
On my plow trucks , I never use the plow shoes . I run meyer plows and when you get snow in front of them they lean a bit so the edge is on the pavement . But I dont do gravel roads or lots , I need the cutting edge on the pavement for a clean plowing.
Swict 78in Bucket Skid Steer Attachment (A64553)
Swict 78in Bucket...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A64556)
2022 Mac Trailers...
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
2019 HYDREMA 922F HM ARTICULATING DUMP TRUCK (A65053)
2019 HYDREMA 922F...
2020 BERGMAN C815S ARTICULATED DUMP TRUCK (A65053)
2020 BERGMAN C815S...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
