When will tractor manufacturers finally offer a front 3pt and implements for CUTs
   / When will tractor manufacturers finally offer a front 3pt and implements for CUTs #11
   / When will tractor manufacturers finally offer a front 3pt and implements for CUTs #12
Judging from the way the dirt looks, and the way those guys are dressed, I think the ground is partially frozen during the tillage. Some real nice gear there.
   / When will tractor manufacturers finally offer a front 3pt and implements for CUTs #13
Actually, you do see horses pushing wagons. They don't pull them. ;)
But the load is behind them, not in front of them.
It takes a Hoosier to grasp this concept. I get it because I was born in Kosiusco county. You can't pull something unless you are pushing it.
   / When will tractor manufacturers finally offer a front 3pt and implements for CUTs #14
If the brush hog was in front, the ground bees would have a much easier time finding you !!! :)
For some implements it would work great, others like a moldboard plow or chisel plow it would not. Lose all traction and be a rough ride. There is a physics equation in there somewhere as far as the amount of energy needed in pushing versus pulling.
   / When will tractor manufacturers finally offer a front 3pt and implements for CUTs #15
Whereabouts?
   / When will tractor manufacturers finally offer a front 3pt and implements for CUTs #16
Well, I have a tractor with ALL attachments in the front, so here goes....
Ground engaging implements like dirt plows, box blades, etc... are better off in the back. When implements in the front get stuck in the ground, the tractor tends to want to ride up over them, lifting the front wheels off the ground, breaking any 4 wheel drive traction on the front wheels and adding tremendous weight to the rear wheels, increasing their ability to crawl up over the front mounted implement.
Tractors, with their large rear wheels, are fundamentally designed to PULL.
Specialty light cultivating tractors, like a Tuff-Bilt, have a front linkage for shallow row crop cultivating.
Tuff-bilt Tractor System - Affordable and Innovative
Ag size (100+ hp) tractors are so big and strongly built that they can handled a LIMITED amount of front end work. European tractors, which run on roads more than US tractors, frequently have equal size front and rear wheels.
Ohio built Ventrac tractors, which have equal size wheels, are available with Three Point Hitches front and rear. Golf courses buy a lot of Ventracs, which are the right tool to mow slopes. Not too strong at PULLING, relative to a 'regular' tractor.
Ventrac Compact Tractors & Attachments
While there are specialty tractors for every need there is no single tractor that is optimal for all needs.
Skid steers and wheel loaders are fundamentally designed to PUSH.
   / When will tractor manufacturers finally offer a front 3pt and implements for CUTs #17
Specialty light cultivating tractors, like a Tuff-Bilt, have a front Three Point Hitch for row crop cultivating.
Ag size (100+ hp) tractors are so big and strongly built that they can handled a LIMITED amount of front end work. European tractors, which run on road more than US tractors, frequently have equal size front and rear wheels.
Skid steers are fundamentally designed to PUSH.
WHY ARE YOU SHOUTING??? :laughing:
   / When will tractor manufacturers finally offer a front 3pt and implements for CUTs #18
Mostly it is the mechanical advantage of the larger rear wheels, plus tires designed for traction when tractor is moving forward.
   / When will tractor manufacturers finally offer a front 3pt and implements for CUTs #19
   / When will tractor manufacturers finally offer a front 3pt and implements for CUTs #20
McDonalds hospital, Warsaw.
(4) 12' & 10' Corral Panels (A50515)
(4) 12' & 10'...
2008 Ford F-250 Reading Service Truck (A50323)
2008 Ford F-250...
Woods 3180 Batwing Mower (A50514)
Woods 3180 Batwing...
2016 CATERPILLAR 299D2 SKID STEER (A51242)
2016 CATERPILLAR...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
