super55
- Joined
- Jan 27, 2012
- Messages
- 959
- Location
- Great North of Michigan
- Tractor
- Oliver Super55, John Deere 4310, John Deere 4400, Kubota L2500 (had),
You guys ever think a front 3pt will be as common of an option for CUTs just as front end loaders are now?
I know it's fairly common for larger 150+ hp Ag tractors to have them especially in Europe and I have found a few aftermarket manufacturers in our neighbors to the north that make them in Canada for snowblowers. Maybe it's just me but seems like if somebody came out with one it would have a possibility to really take off.
These are just some of the thoughts. Getting a closer cut with a finish mower would be easier, larger drum mowers could be used because you wouldn't need to offset and go smaller due to weight and one could run a tedder in follow is they wished. Down pressure would actually get a box blade or rear plow to function properly and could tilt hydraulically from the seat. Heck you could even run a tree spade if you wanted. Snowblowers and rotary brooms would function just as they do on rear 3pt. I would love having a front mount bush hog- no more worrying about shrubs pulling wires.
Heck if someone wanted even a makeshift loader they could use something like Pat's Easy mover and add an cylinder and have small loader for wood, dirt, bark, snow or whatever.
I know front mount gear implements are few and far between but most gearboxes on these implements have an access cover to attach from the back of them so I don't think it would be hard to transition to.
