building a cab? you can do it!
/ building a cab? you can do it! #41
I just finished a cab for my 2011 Polaris Ranger 400.Basically I built the sides and doors.The top and back panel are the soft top type that I already had bought.I figure if the top and back wear out I can still add it later.
The framework for the doors is 1"x1" square tube covered by 16 gauge sheet metal.I estimate I have approximately $200.00 in the project.
/ building a cab? you can do it! #42
You wouldn't happen to have a few pics of your build or some plans that you used do you? I have a 2012 500 Ranger that I was going to try to build some doors for this summer. I have the EMP front windshield, Polaris plastic top and a Polaris rear windshield on mine. I am just missing the doors and a HEATER right now.
What they said plus... what a truely professional looking job! I do have a question though.... in the one photo you show the sheet metal being spot welded flat onto the square tubing. On the photos showing the finished product, all of the outside corners appear to be smooth and perfectly rounded. How was that done? Did you use body filler?
thanks for the great compliments, everyone thank you. yes on the body filler. i used fiberstrand, then used finish body filler. first though i grinded the corners deep then put down a deep penetrating bead the whole seam across. i did this to avoid cracking on edges. the spot welds are actually 3/8" holes i drilled in the top panel then it allowed me to mig weld onto the tubbing. i do the same when welding on new car parts in the colision repair world. this stuff is way easier to weld than the thin sheet metal i work with on cars, 18-22 ga. thickness and galvinized on both sides. nightmare, really. this project was enjoyable. now i enjoy it even more when it snows and blows at 35 mph and 27 below zero.
/ building a cab? you can do it! #44
I realize this thread is old.....But....I just bought a new Bobcat CT122 FEL. I am also getting a snowblower attachment. I have been looking for a cab and have been blown away at the prices. Although I am a good at tinkering, your cab looks professionally made! Congrats on that! Do you happen to have made any plans or step by step instructions? Better yet, would you consider building one?
/ building a cab? you can do it! #45
For a basic cab, try Original Tractor Cab they are under $1500 for most of their cabs and are fairly well built.
Aaron Z
/ building a cab? you can do it! #46
Thanks Aaron but I am leaning toward a hard sided cab.
Bill
sorry it took so long to respond, I forgot about this thread. I did not make any plans just winged it all the way. the only way to build another cab for someone is having their tractor for a whole summer.[spare time only] funny how easy it goes once you get started. nothing is really symmetrical or level. you have to customize as you build. you just need a welder, chop saw, jig saw, a few basic tools and patience.
check out my cab build in the bobcat tractor forum. hope it gives you some ideas for yours. i got a bunch of great ideas on here from other people who built their own cab as well. was alot of fun to build and very happy with it.
I have more build pictures in other forums. look in my profile under "recent posts or threads started" and click on anything that mentions a cab. Good luck with your builds and I hope my pictures can give you some good ideas.
/ building a cab? you can do it! #49
I'm glad you re-posted, 4bangdan ( by the way, Merry Xmas ) that was a nice job you did.
One thing that caught my eye was, "the computer fan" you used. How did this work out for you,
did it have enough power to blow out hot air for you?, or would you have done it differently?
/ building a cab? you can do it! #50
I also use 12 v computer fans and find them very effective, push high volume of air, low noise and low amps plus compact. Win Win!
/ building a cab? you can do it! #51
I sure would like to see a picture of one set up.
/ building a cab? you can do it! #52
1999 to 2003 dodge Durango rear gate swing about 110/0. put it to right side about 1/3 of the with BOB - DSC04231.JPGBOB - DSC04231.JPG
/ building a cab? you can do it! #53
DSC04233[1].JPGDSC04230[1].JPG I built most of this cab I I got the fram maid th rest
The fan works great, low noise and low amp draw. I use it too cool in the summer and to keep the air moving in the winter for dry windows. I have a fresh air intake heater below the right side of the winshield. It is a must. Tried 1 winter without a heater and the windows were always sweating. Also the computer fan is actually about 7 inches diameter. Not from a computer but it is the same type.
/ building a cab? you can do it! #55
Great job,
I just acquired a cab from a Kubota F3060, which I'm going to remodel to fit my MX5100. Purchased from a local AG recycler for $475, complete with heater, lights, wiper, turn signals. In decent shape, will take about 10 hrs to reshape the contours and fill in the gaps with sheet metal, then a couple hours to clean and repaint.
/ building a cab? you can do it! #56
You got a nice deal there....:thumbsup:
/ building a cab? you can do it! #57
/ building a cab? you can do it! #58
Thanks Skyhook,
Well, the Cab rebuild is taking a little longer than my first estimate, so far about 20 hrs to reshape the frame and door openings to fix the MX, but it is getting there. will post pics when i get it back on the ground for paint.
/ building a cab? you can do it! #59
Thanks Skyhook,
/ building a cab? you can do it! #60
Cheap heater parts.
More Information for SPECTRA PREMIUM / COOLING DEPOT 94489 New 6x6 aux heater core from/for a 2003 Astro on rockauto for 33 bucks,
16-1455
16-1456
16-1390
Three item #s above are for 12vdc fans on surpluscenter.com that would be about right size $10-20 each.
Now all I need is a cab.
Next year.
Maybe get the frame and roof part of it done for summer to keep that sun off.
2019 HAMM HD+140IVV DOUBLE DRUM ROLLER (A65053)
2019 HAMM...
2 new 10'' Pallet fork extensions (A61567)
2 new 10'' Pallet...
POULAN 44" VINTAGE 2 MAN CHAINSAW (A64276)
POULAN 44" VINTAGE...
2021 Ford Transit 350 HD Reefer Box Van (A64194)
2021 Ford Transit...
2006 Utility 53Ft T/A Reefer Trailer (A64194)
2006 Utility 53Ft...
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
