lxx60 series recall
/ lxx60 series recall #1
BGigHarbor
Gold Member
GIg Harbor ish
.l5460, bcs 725, 852
Sorry if this is a dupe thread. I've been really busy lately and haven't kept up reading the forum. If redundant, please delete the thread.
I got a call from my dealer today and they said there is a mandatory recall on a turbo hose on my l5460. They will come out sometime in the next couple weeks and replace it.
Just thought I'd post in case anyone else had a lxx60 turbo and had not heard about the recall.
/ lxx60 series recall #2
I haven't heard if this. Is it the hose in the pressure side of the turbo?
The dealer tech came out and put in the new hose. I haven't had a chance to check it out yet but I saw the part itself. Was a rubber "adapter about 2 inches in diameter (slightly bigger on one end) and around 3 inches long that is held in by hose clamps. I'll take a pic later to show the exact location.
I guess it is only the early lxx60s with turbos (as well as some non tractor dpf engines if I understood correctly). The latest runs do not require the update. I was told one sympton of a bad hose was a sooting issue and the engine unable to regen.
2020 MACK GRANITE (A60736)
2020 MACK GRANITE...
4'x6' Stack of Sheet Metal (A60463)
4'x6' Stack of...
2020 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2020 DRAGON 150...
2025 AGT Industrial MX-CRT23 (A60463)
2025 AGT...
Set 4 - 12-16.5 tires on wheels for bobcat (A61567)
Set 4 - 12-16.5...
1005 (A61166)
1005 (A61166)
