Charging Batteries
/ Charging Batteries #1
kenmac
Super Member
The Heart of Dixie
McCormick CX105 Kubota MX 5100 HST,
Well, it was nice here this past weekend .So, I decided to crank up the o yanmar... Turned on the switch and tried to start... Nothing :mad:. Well, I go to the garage and pull out the battery charger. I set to 40 amps 12 volts set the timer to 45 min.Made sure the cables were connected correctly.. Hit the on switch to start the charging. Went up to the garage to do something while the battery was charging. All of a sudden , I hear a BIG BOOM !:confused:. I walk back down to the tractor shed and found the battery in many pieces .. That's right,, the battery exploded.. I guess It had an internal short to start with is why it was dead, but I don't know.. Anyway,, Be careful charging or jumping off batteries. I have charged / jumped off many batteries in my life time, but this was my 1 st battery explosion !...... $78.00 later and the yanmar is up and running ! :thumbsup:
/ Charging Batteries #2
Very lucky you weren't next to the battery when it happened!
Could have been caused by several things -- low electrolyte level which allowed a spark between plates, corrosion somewhere leading to a spark, or a little slop in the clamps or charger jaws that caused a spark. It's always important to look over a dead battery very very closely before charging.
/ Charging Batteries #5
Wow, that is very scary. Not being critical, but do you think the 40 amp charging rate had anything to do with it? I just bought a jeep that had an old battery in it and I tried to charge it but thought trying it a 2 amps and doing it slow would be less dangerous. The battery was junk, but am wondering what the safest way to charge is?
/ Charging Batteries #6
Your only suppose to turn it on 40 or higher to crank right? I have never charged at anything over 10-12 and try to always charge at 2amps.
I thought those were just charging settings for getting one started taht was really dead or like my father in law who owned an auto shop used them for when cars came in that they needed to crank lots while working on them and they had an older battery, they used that setting when cranking it.
A logger i know went to unhook his big battery for his boat from the charger and it blew up on him. I am talking one of those massive bateries for like huge dozers or the old schoolbuses.
/ Charging Batteries #7
I kind of think a 40 amp charging rate is pretty high, also. On a totally dead battery - where you do not know why its dead - IMHO, I would start at around 2-5 amps and make sure the battery would accept this prior to going to higher amps.
In any case - thank the Lord that no one was injured. I met a person who became directly involved in a battery explosion - the facial and hand disfigurement was extensive. He was exceedingly lucky to not loose his eyesight.
/ Charging Batteries #8
I have an old Schauer roll around charger that goes up to 60amps on 12 volt. I have used it on high amps numerous times. Doesn't seem logical to me they would have the high amp settings unless it was ok to use them.
/ Charging Batteries #10
If using a charger put the ground clamp on something other than - post on battery . Turn it on , then walk as far as the cord will let you then plug it in . This keeps your face out of range . If using a vehicle to jump start hook up the live battery last . Again ground on something other than the battery on the dead one . Always hook ground up last on any connection . There is no circuit till you hook that ground . And make **** sure you have cables hooked up right .
/ Charging Batteries #12
I once had a big yellow EverStart Maxx from Wal-Mart blow up when I hit the start switch on a MF 231. It had never given me any trouble or indication that it was going bad until it did that, and blew the grill out of the tractor. Luckily the force went forward, and not backwards into the radiator. It was untouched rearward.
/ Charging Batteries #14
I have one of those batteries that just went bad in my saturn last night.
Walmart got of their prorated warrenty just before i bought it and at the time did not realize it till later. i no longer buy batteries from WM due to that. NOw my battery went dead 4 years later. Was a 3 year free battery so it was a high dollar one, the replacement should be about half if they prorated!!!
/ Charging Batteries #15
hmm...battery explosions seem to be more common than I ever realized.
I've jumped lots of vehicles without problems....guess I'll be more careful from now on...I like the concept of hooking up the "good" battery last when jumping.
Glad you're OK, OP.
/ Charging Batteries #16
This helps me remember what to attach last:
A battery emits explosive gasses while it is charging. So don't make the final connection anywhere near it!
Instead make the final connection far away from the bad battery, to a grounded part of the vehicle providing the charge. And as far from that vehicle's battery as is practical.
And when using a charger, this gassing is why you turn on the charger as the last step. Never attach a charger's cable to the battery with the charger turned on.
Keep in mind the source of the gas and it's easy to think what to connect last.
/ Charging Batteries #17
Never was big on jumping off Veh.s. I've done my share but what makes me think back is my old Ranger bass boat. I had a onboard Elec.charger and 4-12v. batteries under a back compartment connected to it. And 30 Gals. of 2Cyl. Gas next to them. Kept that Boat for Yrs.and Never had a Prob. of a Battery Exploding myself. Those batteries got abused. Literally:ashamed: Your Correct that at least they were all connected Cal. Seldom having to change a Trolling Motor.
I like you , have charged numerous batteries on the 40 amp scale ,and never had a problem. Mine is like kinda like yours' ,but different brand. It has 200 amp jump start which I didn't use this time . only had it on the 40 amp scale. The battery was only a couple yrs old ..like I said,, been charging and jumping off batteries for a ling time (since I was a kid) never had 1 to explode.. I can now say, I've had my 1 st and I hope it's the last. Never thought a battery exploding would be that loud.. Really never given it much thought..
/ Charging Batteries #19
My Schumacher Electric Battery charger has a safety selection switch. One for Manual, another for for semi-auto, and the third for maintenance free/deep cycle. If doing the manual mode, there is no safety option. The semi-auto and main free has a safety feature to prevent the battery from exploding and the battery is sampled via circuit monitoring.
/ Charging Batteries #20
When I made a comment of abused Batteries. The Trolling motor was 24V. that you jumped the Pos. terminal to another Battery's Neg. and Neg. to the Pos. to get 24v. I did remove the cables when I would put a Chrg. on them. Just 2 Typical Thumb Nuts. But the Charger stayed connected unless I had to replace the Battery. If I recall it was a 60Amp. Chgr.
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
Caterpillar Information Guides (A63117)
Caterpillar...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2016 Volvo VNL T/A...
2340 (A64281)
2340 (A64281)
2008 Big John 42' Log Trailer (A62613)
2008 Big John 42'...
