5075e Tool Box Location
/ 5075e Tool Box Location #1
LoudonNH
Culpeper, Virginia
2016 JD5100M, 2014 JD5075E, 2024 JD3039R, 2023 JD X730
I recently bought a new, 2014 5075e with H240 loader. There is a small plastic tool box mounted on a two-piece, bolt-on bracket at the left side of the loader and just above the fuel tank cap. Needless to say, it's in the way Any ideas on a better location for it, or perhaps mine is not properly mounted.
/ 5075e Tool Box Location #2
Maybe you can think up a better location and a better box for tools. Would like to see it.
Mine is located in the left fender, but I can't use it because I made a chainsaw holster that sits just above it.
Can carry a few tools in the pan under the seat, such as tape measure, garage door opener, felling wedges and the like. But not a great place for them.
What is the thermos-looking jug just below the tool box?
That's where the fuel goes in. Now you see the problem.
/ 5075e Tool Box Location #4
I need to find out why they didn't install the tool box on my tractor! Why don't you like it there?
Brett
Brett
It's a great spot for a toolbox except for the fact that you can't fit a 5 gallon jug in there to get all 5 gallons out of the can. There's also not enough space to fit a funnel in there. (I like to use a large funnel with a screen in it.)
/ 5075e Tool Box Location #6
Yup... Sorta a PITA. I swiped my kids snowmachine gas can with a long, flexible poly spout. Works good, but no filtering.
AKfish
/ 5075e Tool Box Location #7
Sounds like a good excuse to buy a transfer tank.
/ 5075e Tool Box Location #8
Yeah, saw a real nice towable one on CL. Pretty new.. IIRC, just over $4k.
AKfish
AKfish
I've been trying to get along without a transfer tank in the bed of my pickup because I need the space to haul things. Will probably end up getting a tank with lifting ring at some point, rather that the L-shape tank and tool box that would be very useful but a pain to remove.
One thought I had today is to hinge the tool box bracket on the tractor and add an even bigger tool box.
Larry, your mention of your kids' gas can got me thinking I might just track down a large plastic funnel with long flexible tube attached. I'm sure I've seen such a thing.
Thanks guys.
/ 5075e Tool Box Location #10
I'm so glad I'm past the days of filling tractors with 5 gallon cans. Boy oh boy was that a pain.
Either a transfer tank in the bed of your pickup, or a small trailer with one mounted on would be perfect. Lowes has a 6x3ft one for about $400 I think. Bolt you a 100 gallon tank on it and your all set.
Solved the problem for now by removing the tool box and its bracket.
I don't mind using 5 gallon cans to fill my tractors. The fuel is always fresh!
Incidentally, I was able to buy some oversize, non-vented, after-market spouts for my cans that make the process much faster. They arrived by USPS today.
Will probably put a tool box in the back of my pick-up since the truck is always at the same location as whichever tractor I'm operating anyway…
/ 5075e Tool Box Location #12
I realize its an old thread, but if you still have the bracket on the shelf, we had the same problem, I flipped it upside down and mounted it on the right hand side. I just had to drill a couple new holes in the bottom of the toolbox to remount it. Sorry I don't think I have a photo of it anymore, we traded that tractor. I also used it to hang/store my chain and I just bungeed the bottom to the loader hoses to keep it from swinging around.
/ 5075e Tool Box Location #13
Do you have the part number of that toolbox bracket? I would love to buy one to add to my open station, since my tank is behind the seat I don't have the issue with the filler and I also use 5 gallon cans to fill up.
/ 5075e Tool Box Location #14
If this is it, key 3 is part number SJ14345
/ 5075e Tool Box Location #17
They should make them for free. That's how the Gov't works. They get free money. ;)
/ 5075e Tool Box Location #18
WoW! That box ( post #14 ) looks just like the next to worthless one behind the seat of my Kubota. I guess I'll just learn to love it and not chuck it. It does hold my roll of TP and my dibble wrench.
/ 5075e Tool Box Location #19
Pic of your box and for sure, a pic of the "dibble wrench". Know what a dibble is, but not a dibble wrench. :confused:
/ 5075e Tool Box Location #20
Toolbox and dibble wrench - OK. It's going to take me just a short while. Chance to get some new pictures.
Finally - some pics. The dibble wrench is used for the final match-up between the implement and my 3-point system. Shove the dibble all the way thru - pull it back out - the hitch pin should go thru easily. Dibble wrench - Klein Tools.
