Satoh Block Heater
/ Satoh Block Heater #1
BeaverBFTD
Seattle, WA
Satoh S370D
Does Anyone have a part number/source for a block heater for a Satoh Beaver S370D?
/ Satoh Block Heater #4
The only problems I encountered are due to the heater itself failing. You'll need to remove the starter to reach it. And drain the coolant of course.
/ Satoh Block Heater #5
If the engine is the 3 cyl diesel (K3), on mine it is located behind the oil filter, but guess any frost plug location will do.
/ Satoh Block Heater #6
The 370D uses a 2cyl engine. I need to pull the starter on mine one of these days to reconnect the plug for said heater. Somehow it wasn't properly seated.
/ Satoh Block Heater #7
Do you have an update on how the installation went?
I have an s370d that I will be bringing to Minnesota this spring and am planning on adding a block heater. Any insight or tips on the installation are greatly appreciated!
I ran in to a bigger problem. Looks like I may need to rebuild the engine. Once that is done it may start just fine without the block heater.
2023 CATERPILLAR 150 AWD MOTORGRADER (A63276)
2023 CATERPILLAR...
Cat CB24B (A60462)
Cat CB24B (A60462)
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
(1) New 7ft Chain Sling (A61166)
(1) New 7ft Chain...
2016 VOLVO EC250EL EXCAVATOR (A62129)
2016 VOLVO EC250EL...
Arrow Quip Head Holder (A64047)
Arrow Quip Head...
