Satoh Block Heater
/ Satoh Block Heater #1
BeaverBFTD
Seattle, WA
Satoh S370D
Does Anyone have a part number/source for a block heater for a Satoh Beaver S370D?
/ Satoh Block Heater #4
The only problems I encountered are due to the heater itself failing. You'll need to remove the starter to reach it. And drain the coolant of course.
/ Satoh Block Heater #5
If the engine is the 3 cyl diesel (K3), on mine it is located behind the oil filter, but guess any frost plug location will do.
/ Satoh Block Heater #6
The 370D uses a 2cyl engine. I need to pull the starter on mine one of these days to reconnect the plug for said heater. Somehow it wasn't properly seated.
/ Satoh Block Heater #7
Do you have an update on how the installation went?
I have an s370d that I will be bringing to Minnesota this spring and am planning on adding a block heater. Any insight or tips on the installation are greatly appreciated!
I ran in to a bigger problem. Looks like I may need to rebuild the engine. Once that is done it may start just fine without the block heater.
Arrow Quip 10' Heavy Duty Bow Gate (A64047)
Arrow Quip 10'...
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
2016 KUBOTA SVL75-2 (A64047)
2016 KUBOTA...
DURA-CAST PRO-LICK TANK (A62131)
DURA-CAST PRO-LICK...
2021 VOLVO VNL860  6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2021 VOLVO VNL860...
80003CFL (A61568)
80003CFL (A61568)
