Portable shelters
/ Portable shelters #1
K man
Quadeville, ont
2014 Kioti CK 30 HST with cab. 2018 Cub Cadet Challenger 750 EPS UTV
Hi everyone, would like to get some feed back on pros and cons of portable shelters. I have seen them being erected all over the place as garages. What I want to know is are they worth investing etc. Thanks for any input.
Gilles
/ Portable shelters #2
Gilles
Assuming you are talking about the metal carports that can be configured in many ways? Very common around here. I have a 18x28x8 coming soon, I hope. Its ordered, just waiting for delivery from HBO carports.
/ Portable shelters
The ones with the canvas tops.
/ Portable shelters #4
Oh, ok. I've had two of them. Notice I said "had". There snow load is terrible. I was constantly removing snow durring heavy snow storms. I see many collapse every winter. Covers last 6-8 yrs or so depending on how much sun hits it. Some put a "sacrificial" tarp over the original to make them last longer.
/ Portable shelters #5
Hi TBN
Portable shelters, if you buy the Best kind and do a good job putting them up, are worth the cost and do last for ten years.
I have a 35 x14 foot Shelter Tech structure made in Canada (Woodstock NB) with the CANADIAN heavy duty specs. It cost me three thousand dollars and has supplemental diagonal braces made from steel conduit rods with tripled tie down anchors on a fine-sized crush base two feet thick. It has withstood two hurricanesd and three bad winters of heavy snow, without a problem. THERE ARE pros and cons. No security from theft is the biggest con. No property tax increment is the biggest pro. It is very robust and very effective. It has curtain doors, not roll up nor zipper doors, closed with bungee cords. I like it. It took three men two days to erect it.
/ Portable shelters #6
Had one. cost about $400. I had to travel and it snowed wet heavy snow. About 8", came in late in the evening, checked on it the next day it was nothing but a pile canvas and bent metal. If you can keep the snow off, I'd say ok.
Wedge
/ Portable shelters
Hey jix how are they for condensation inside the roof. Does the equipment get wet etc. I am in Canada so will go visit their website thanks.
Gilles
/ Portable shelters #8
I have had one for three winters fo r my boat,, tne marine railway takes my boat in during the summer and in the winter i put the ends in to keep the weather off
It is made by shelter logic,, available at crappy tire
I keep the snow off it as they are not the strongest structure but easy to erect and works for me no permits or taxes
havent seen any condensation in it as air gets under the ends
/ Portable shelters #9
I have two. One cheap for summer use and one expensive for winter use.
In many Canadian communities, there are by laws requiring you to take down the fabric in warm weather to please neighbors.
No complaints equals no municipal action.
I always leave one end open for convenience
Removing snow is a must. People have been killed by being inside when it collapsed.
Dont rely on tie downs provided by manufacturer or the wind will take it away.
Duckbill anchors are one effective solution to wind.
About Duckbill Earth Anchors | Foresight Products
The sun is very hard on all of them. The more expensive ones have some UV resistance.
To make my expensive one last I take it down every spring before the sun gets strong.
No problem with condensation.
Dave M7040
/ Portable shelters #10
I have a 14' x 22' x 10' round top shelter from MDM in Connecticut, it has zip up doors front and back. I bought it 8 years ago for about $600 and anchored it with the cable anchors they provide with the kit. After about 5 years the cables started to rust and snap in winds over 60 mph. MDM said to take pictures of the rusted cables forward to them and they would send me new cable anchors. Instead, I undid the remaining cables, picked the entire unit up and moved it to a spot on my property that is more shielded from the wind. I then bought some 36" screw in anchors and it has been fine since. The most snow I have seen on it was about 1.5 ft of snow, no issues. The fabric is starting to show signs of fading on the sun. I do have a few holes in the door where the wind blew the door up against the firewood that was inside. I also caught the door one time with the level indicator on my new tractor. The fabric had a 10 warranty when I bought it, but today the warranties appear to be more like 2-3 years. I have been happy with the value of mine and I am considering getting one a little taller and longer so I can put the tractor away with the ROPS up and store more of the tractor attachments inside out of the weather.
/ Portable shelters #11
I am considering one for my truck but I would hate to have snow load make a mess of it!
Any recommendations on which brand to buy?
/ Portable shelters
For those who have them how are they for moisture inside on the ceiling. This is a big issue for me if I am to store my tractor, blower, loader when not in use. Winter would be the worst I think for condensation snow on outside of canvas/tarp on warmer days.
/ Portable shelters #13
I don't have any issues with condensation, but after 8 years I do have a few spots where the cover has worn thru rubbing on a few tubing joints at the top and I am now getting some water coming thru. Where I placed my shelter, I first leveled the area, put down a layer of geotextile road fabric and then 2-3 inches of 1 inch crushed rock.
/ Portable shelters #14
I have 2. Both Rhino Shelter brand out of CT./USA. The 10'x20' and a 14'x30', both round, 5 & 3 years old respectively. Proper installation is the key, anchor properly and I do keep them both snow raked if we get substantial snowfall. Truly like them and recommend the brand. BTY during installation I wrapped electrical tape over the joints per the instructions to reduce chaffing and premature wear of the top ---no problems to report, both look like new.
/ Portable shelters #15
My Shelter has shown zero condensation, probably because it is never heated, and if I run an engine inside, I always have one end open to allow lots of ventilation. A previous post alluded to using duckbill anchors. I heartily agree; my shelter has 12 such anchors, driven down about three feet, plus another 8 for the wind hold down straps. The bottom edge has turn buckle tighteners that tension the walls which are of very heavy guage UV stabilized polymer fabric with a reinforcing weave in between the doubled layers of the cover fabric. I elected to get the turnbuckle tighteners to make the edge tension uniform all the way along the wall. Then I placed four of my own manufactured corner braces made from 12' length of galvinized conduit tubing. the corner braces are anchored at the bottom of the door vertical corners and the inner upper vertical struts with clamp brackets and bolts. These diagonal braces prevent the thrust of the wind from causing the shelter to book fold under heavy snow loads (as my neighbors did) in any longitudinal wind forces. These diagonal longitudinal braces are not specified by the manufacturer, but they cveratinly should be, Because without them the structure would certainly have collapsed from repeated flexing of the welded joints of the skeleton frame (causing metal fatigue) My shelter easily withstands a 4 foot deep snow load, with rain on top of that. The shelter fabric will support three men walking on top without visible deformation. Of course the top is rounded, not flat. If you let hot exhaust to blow on the plastic, it WILL quickly melt, so you have to avoid that. In wind it is best to tightly close the curtain doors since they will scuff on their doubled) lower edges. There is another one of these SHELTER TECH buildings in an unshelterd area next to the St John River nearby. it is much bigger than mine is and has been standing undamaged fot eight years now, Through three hurricanes. THEY ARE THE BEST TEMPORARY SHELTERS THAT MONEY CAN BUY, IMO PRICEY YES, BUT YOU GET WHAT YOU PAY FOR...AND YOU CAN TRUST THEM TO STAY UP. (No, I am not a shill for shelter tech, just a guy that recognizes excellence and likes to have to do things only once)
Yes, you do have to follow the instructions carefully..and place foam tape at the wear points of the shelter where it stretches over the skeleton frame, Yes you do have place it on dead level ground with a decent thickness of fine crusher dust. One foot or more.
I reccommend buying a lot of extra duckbill anchors as well, one for every vertical part of the skeleton, and at least four wind straps also with duckbill anchors.
Duck bill anchors cannot be removed once driven into hard ground for three feet, not even with an FEL. It takes a ten pound sledge and a day of sweat to drive them in...but they STAY PUT in a hurricane, in fact in two hurricanes now. That is why I specified a tubular steel lower edge to mine. the streses are distributed evenly all along the wall, not at eyelet points.
My shelter is over-killed. That is a good idea. If you don't, then it could be a heck of a mess to set to rights, and cost away more than the extras I mentioned.
I never remove snow accummulations, usually it slides off, unless you already have freezing rain stuck to it
/ Portable shelters #16
I have the shelter logic 12x24x10 feet high, round top.
After about the fifth year, the fabric will start to sweet in some spots,
I purchased another tarp to just cover the "top" portion and that solved the problem.
Should be good for another year or two, I plan on buying another one and doubling the frame inside
(keeping it the same dimensions, but stronger framed) eventually, I will frame it with wood.
Keep the heavy snow loads off and there fine.$500 bucks is well worth it for me.
I did add an addition to mine at the back, making it a total of 30 long. I like it.
/ Portable shelters #17
Thought I would comment as I had a 10' x 20' x 10 temporary shelter bought from Canadian Tire.
My one lasted until the first wind storm and then got carried away even though it had concrete blocks and railway ties as anchors. My fault as I did not pay enough attention to anchoring the shelter to the ground. That said, depends on what you want it for and how big do you need to go. Also there are the local municipality rules regarding sheds, shelters etc.
For me, if I needed another temporary shelter I would go the used steel container route providing I didn't need the extra height or width.
Everyone's situation is a little different - as is the time of day you consider these things :) At least with threads like this, you can get a fairly good cross section of opinions and enough variety to help in your decision making.
/ Portable shelters
Thanks all for posting you experiences with the shelters. I am not a cheap guy and not afraid to pay big bucks for a good quality shelter that will last and endure out harsh winters here in Ontario. Reading from guys who live on the East Coast they know for sure what it is to erect a shelter that will withstand the Hurricane winds coming of the Atlantic Ocean which can be very strong. I have kept track of the company names recommended by you Canucks and will find review etc on those shelter companies.
I may still just go with a Carport 30x30 with a steel roof and then close the sides in over the next couple of years. Still debating on what to do. So again thank you all.
Gilles
/ Portable shelters #20
Don't buy the cheap ones, they are crap. The fabric has no UV protection and will rot away in 3 to 4 years. The posts are about 4ft apart, they won't handle snow loads
Snow load can be a problem on some. Make sure the uprights are not more than 3ft apart.
Condensation, mine does sweat a fair bit. I just replaced the top with a better quality one with vents this summer, hopefully this will help.
Anchor them well. I used crushed rock on both side and 1 end to secure mine to the ground. I get lots of wind all yr long.
Mine is a Cover Tech shelter from Woodstock NB, They ship to the states all the time. I've had it for 4 years, it's well made, but i should have bought the better quality top from the start. I have the better top now.
1998 Freightliner MT45 Step Van Food Truck (A61573)
1998 Freightliner...
2006 Hitch and Trailers Inc. 12ft S/A Utility Trailer (A61574)
2006 Hitch and...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
UNUSED KUBOTA 48" PIN ON BUCKET (A64280)
UNUSED KUBOTA 48"...
1996 Great Dane 50' x 102" Reefer Trailer (A62613)
1996 Great Dane...
2019 John Deere 4044M (A62177)
2019 John Deere...
