Shuttle versus HST
/ Shuttle versus HST #61
Yep, I was thinking of you in this discussion Larry, knowing you regularly operate both kinds. I only ran my Brother's L3240 intermittently. I was always reaching for the shuttle lever to change directions. :)
You should see me and my son when we work together and swap between tractors, we pull up door to door exchange tractors then sit there a minute with blank looks on our faces while figure out how ti get them rolling.:laughing:
I bet we had our 8540 for six months before we stopped instinctively using the foot clutch like on our old Case synch shuttle.
As mentioned previously, I think a lot has to do with how much and how often you use a machine. My use of all our tractors has decreased and operation is no longer as good or instinctive and won't approach that of a frequent user. I can sure tell the difference from when I was farming.
/ Shuttle versus HST #62
As a hobby farmer, I am not in a hurry. My HST rarely goes back to any sort of neutral. With saftey switches your always fumbling with the pedal to find the sweet spot were your tractor won't stall when you get off the seat. With my suspension seat installed and seat switches offline, the tractor will creep along without me on it. With my geared tractors, when they are in neutral, they do not move. I mean how many of us have sat on our HST's trying to get them to start, checking PTO levers, fumbling with the HST pedal, jumping up and down on the seat. True though if you are in a hurry you can sure do the 3 point turns in a hurry, loader work is faster except that I have never been stuck so much now that I have my HST. You try to fill the bucket and as soon as you break traction the tires speed up and dig. With my geared tractor, the tire speed is constant and you have much better control filling the bucket. Cruise control is nice with HST but not needed with a geared tractor. My wife does prefer the HST though and sometimes that is an important factor.
/ Shuttle versus HST #63
You really think your getting stuck more with HST? I don't have a problem with that at all. Actually its just the opposite for me once I get the sweet spot of a good HST unit I can get a full bucket every time and rarely spin the wheels, I have watched some folks run a HST with their foot too hard on the go pedal and have results like you talk about.
I really don't know what your talking about with having to figure out why it wont start. A proper shut down will net a easy care free start up every time.
If your pedals wont return the tractor back to neutral then you need to adjust something
/ Shuttle versus HST #64
Dave an I must be near the same age. Paul must not be. Or maybe Dave and I just learn slow. I've been thwarted by many a safety switch. Totally due to my negligence of course. :)
/ Shuttle versus HST #65
I much prefer hyd . shuttle over hydrostat . Foot throttle and shuttle for loader work .
Absoluteley . We load several thousand round and big square bales each year and I find nothing is as fast loading or as accurate for feathering and touching the load up as mechanical shuttle and foot throttle , I wont buy a tractor without a foot throttle .
/ Shuttle versus HST #66
I am in the market for a new tractor. Currently have around 32 acres of fields to brush hog, want to plant some food plots, and I am putting in a ~1100 ft gravel driveway. After reading a lot of post I figured I needed to be in the 35-45hp range for a tractor and want one that comes with a FEL. With prices and considering the dealers, I have narrowed it down to the Kioti DK40 or DK45. They have 2 in stock, the DK40 is a shuttle shift and the DK45 is the HST, both have FELs that come with them.
Given mostly will be using this for what I posted in the first sentence, what are the advantages/disadvantages to each of these? Besides the obvious that the shuttle is more manual.
BTW...pricing given to me today was $22K for the DK40 and $25K for the DK45.
Thanks!
I currently have a Kioti CK30 gear drive tractor that I have over 2000 hours of seat time on. I just recently bought a Kioti DK45hst because I wanted a bigger tractor. I have about 43 hours on it so far. I am going to be in the minority but I am much more comfortable on the gear drive than the HST. You also have the issue of the Hyd filters every 200 hours at a little over $100. I got a super deal on my DK45 at $20,000 as it only had 22 hours on it and looked brand new. I do tractor work for a living and put alot of hours on my tractors. The HST is superior for mowing and I am sure in time that I will get used to the HST. However if there had been a DK45 gear model at the same price that is what I would have gone with.
/ Shuttle versus HST #67
imho...hst is useful in close quarter repetitive work. but if the operator is in good shape all around, so is the hyd shuttle w/gear. really, it's the condition of the user that makes the decision. the demographics of this forum is (i think) made up of smaller private compact tractor owners getting ripe in their years, so i see a lot of favor for hst. not for me to say what's better. better for you to look closely at your particular application (therefore size of tractor) and also how agile you are to handle repetitive clutch depressions vs hst pedal (easier) actions (how are your knees holding up? :). whatever it is, smart move to ask on the forum ....plenty of opinions. if your tasks are large...ask yourself why don't larger m series (kubota) tractors have hst? all the best
/ Shuttle versus HST #68
I have had my McCormick hst 50 hp which is similar to kioti 50 hp hst. I drove the kioti shuttle and hst. Glad I went with hydrostatic. Really simple for my wife. But depends on the user. Hst is by far the easiest to teach if you have multiple operators
/ Shuttle versus HST #69
After 22 years of manual gears, I switched to HST due to advice from members on this forum. I am so glad I did. I do all the same work in less than half the time with a quarter of the fatigue compared to previous gear tractor. I am so much more productive and almost 3 times faster with every single job compared to the previous tractor.
I have a Kubota L3200 (32hp) 4wd HST. I have 12 different attachments excluding trailers. I plan to ad a FEL, third function valves and a few more attachments next quarter.
I use a 6' bush hog mower, medium gear in 4WD, nonstop mowing 2-4' of grass for 10hrs a day, one tank of fuel, approx 5 gallons and always have some reserve left.
Was it a power reverser? I find that I can get work done the same speed if not faster with a power reverser over HST although a shifting gears like on a JD 3005 would be slow as **** in any application.
/ Shuttle versus HST #70
Age has nothing to do with it except for maybe some patients that I didn't have when I was younger.
I learned on a gear and have worked many different tractors and heavy equipment over the years. I actually prefer a shuttle for the most versatile machine but have absolutely no problems with the HST. Productivity is about the same with some tasks taking just a little longer and others taking less as compared with the gear or the shuttle they also have their ups and downs making it a wash for me. I would have to say for me which I would choose really depends on the task but having a few different machines to choose from I am not limited to being forced to use one machine for all tasks.
/ Shuttle versus HST #71
I agree. I can place my tractor in a precise location with less time and less guess work. Every movement is intentional. I had no idea how well that setup would work until I got my Kubota with Hydraulic shuttle and of course a foot throttle. Bought another tractor yesterday, a Ford 3910 FWD with mechanical shuttle. I was pleasantly surprised when I discovered it also has a foot throttle. Did not know they did that back then. :)
/ Shuttle versus HST #72
various options folks get themselves into... so many controls and way to do things...
to many controls.... left foot / right foot *shrugs* which is which?
forgot to add pictures for... to select a wider range of speed.
--gear shifter, 1-4 forward, 1-3 reverse, center neutral
--single lever for low/high
--low/medium/high
--1-4 gear selector.
-----any combination of above with a button to dump clutch
--electronic clutch, or gear box / transmission, that handles clutch automatically.
--engage / un-engage - 4wd / Mfwd or like.
--engage / un-engage - creeper gears. (very slow crawl)
--FEL 2 levers, 1 joystick
--FEL with 3 funtions for say a grapel. 3 levers, or joystick with 3rd function.
------either above with possibly extra button to dump clutch, more seen on wheel loaders.
then ya have Zero turns.. with 2 hand levers, one lever operating left rear wheel, one lever operating right rear wheel.
--same as above for skid steers, but with a few extra buttons on the levers
--more of a combo lever / joystick setup for skid steers.
/ Shuttle versus HST #73
Ain't that the truth. My neighbor is a retired farmer. Hasn't owned a tractor built in the 21st Century. He's borrowed my Kubota a couple times. When he gets on it he always says "now tell me what all these levers do again". I go thru it, detailing the things he "really" needs to know. He is always nervous when he gets ready to go and tells me to get back outta the way so he don't run over me. :)
/ Shuttle versus HST #74
My tractor is a syncro shuttle. I do almost all my work on steep hills plowing driveways, bush hogging fields, plowing fields, grading driveways, loader work, etc. I also load and unload pallets of cement on and off delivery trucks daily. Syncro shuttle provides exceptional control and clutching is not an issue what so ever. In fact, I bet I can complete chores as quickly and accurate, if not better than using an HST tranny. It really comes down to what you're most comfortable with. Esentially, you're paying an additional $3K for HST (as you net power will be about the same).
/ Shuttle versus HST #75
My Massey 1533 has the Power Shuttle and I really like it
/ Shuttle versus HST #76
I've driven a gear tractor for 25 years. I now have an HST.
I'll never have a other gear tractor.
/ Shuttle versus HST #77
My 2 cents, if you are using your tractor for loader work get HST, if its for field work get a shuttle. I use my Kioti for food plot work and cutting big fields, which I prefer the shuttle.
/ Shuttle versus HST #79
I agree 100%.
/ Shuttle versus HST #80
I agree 100%.
Yeah, I think tractor size comes into play also. When you get up above 50HP the uses of the tractor tend to change.
I don't mean to offend anyone so am giving my disclaimer up front. No arguments desired. Just my opinion. Tractors in the CUT size and down are generally used for light chore work and small tasks. 90% of their life is spent doing tasks that they easily handle. Repetitive, low power requirement tasks. In that World HST shines.
Large CUT tractors and up into the Utility or AG class tractors are generally used for heavy FEL work, medium duty chore work (carrying two big bales) and larger occasional ground engagement tasks. 90% of their life is spent doing tasks that require their power and weight. Monotonous, grueling taks. In that World Shuttle shines.
2016 F-250 4X4 (A56438)
2016 F-250 4X4...
UNUSED RAYTREE REDM32 - 32" EXCAVATOR DRUM MULCHER (A62131)
UNUSED RAYTREE...
2017 CATERPILLLAR 938M WHEEL LOADER (A62129)
2017 CATERPILLLAR...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
UNUSED KJ 20'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 20'X12'...
2019 Chevrolet Tahoe 4x4 SUV (A61569)
2019 Chevrolet...
