Tilling Tips
   / Tilling Tips #11
If I ever get a flat land garden I think I would use construction site panels for fencing, so it could be moved easily for equipment to work.
Bruce
   / Tilling Tips #12
When you're finished tilling, you could make one pass ACROSS each end to level it out. Then you'd only have one starting and one stopping point on each end to level out by hand.
This is what I do. Raising and lowering while in motion helps as well.
   / Tilling Tips
The next time around, I'm going to try Jarrod's method along with a slower rpm at those ends.
   / Tilling Tips #14
Yes, your experience is simply the way a tiller works.
The tiller essentially moves the garden soil about a foot behind the tiller when it is lowered. Thus, at the beginning of the run there is a mound and at the end of the run there is a ditch (hole).
If you can get to your garden from all four sides, then there is a solution.
1. Till and then turn around and till the other direction. This will displace the soil a foot in the other direction and the ground will be evened out...close, but not perfectly.
2. If necessary, then till the ends peperpendicularly to the original passes. This will leave a one tiller width depression and hill at the ends. Turn around and make a pass to even that out. If this technique isn't perfect then there is only a one tiller width issue at the ends of the garden to hoe or shovel. This step can be skipped if the first "back and forth" step is done very well.
It takes a bit of practice to hit the hill/depression just right.
I have used this technique for years with quite satisfactory results. I have access to my garden area from 3 sides because of fencing. So working on the method in #1 above is worth the time and effort to become skilled at it in just two passes.
   / Tilling Tips #15
I think everyone has the same issues, regardless of what direction the tines rotate; either the humps at the start or the end.
I keep the tailgate low, try to "feather" the entrance & exit (KK 5'--throws material backwards), and alternate directions tilling, but the entry & exit are always there. All my land has slope, so I use the lower "exit" uphill to set up my irrigation in.
I think its the tradeoff of lowering a spinning cylinder into the dirt to move material; a little handwork at the end instead of long stretches...
   / Tilling Tips #16
This is also what I do, too.
If you till in alternate directions, so there are start humps next to finish troughs, then it will level out nicely.
If you till in the same direction, leaving a row of humps at one end of the garden and a row of troughs at the other, then it doesn't work so well. Sometimes I choose to till this way. To get everything even again, I use the FEL to move the hump material to the trough. Sometimes, if nobody is watching, I might even use a shovel and iron rake to get a really level surface, but that's just between us.
   / Tilling Tips
Oh Man!!! I'm getting some good ideas with this thread and maybe it is helping some others as well.
   / Tilling Tips #18
I just till from one end of the garden in the spring and in the fall I till from a other. I just live with the hole and the hump is littler because it is in last times hole. Yes I circle the garden and only till in one direction.
   / Tilling Tips #19
This is what I do if I'm tilling the whole garden up first. Most time I till and plant in sections though. So I till the ends (perpendicular) full length first. Then as I till the rows I gradually lower to begin and slowing lift the tiller at the end of the row (since the soil has already been worked) and that reduces the humps and trenches quite a bit.
   / Tilling Tips #20
I set the position control stop on the 3ph so the tiller clears the ground about 3" or so. When I get to the end of the row, I just lift it up. Most of the time it raises fast enough to not leave a mound. I never disengage the pto while I'm tilling. I'm always moving before I drop the tiller in the ground. Like a pervious poster said, tilling perpendicular to the row ends helps a lot too.
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55302)
2015 Ford F550...
202476 (A54757)
202476 (A54757)
DEUTZ MARATHON...
CABINET OF HOSE ENDS (A58214)
CABINET OF HOSE...
12V Diesel Fuel Transfer Pump (New/Unused) (A59225)
12V Diesel Fuel...
