Loader Max28 FEL Question
/ Max28 FEL Question #1
Mowin Fool
Member
Mansfield, Ohio
Mahindra, John Deere
I have a 2013 MAX28 with a FEL that I use a set of pallet forks on and it seems as if the last couple of times I have used them on about a 800 Lb load in the bed of my truck it will lift the load a couple of inches and then just stop. Could it be a ball check issue?
/ Max28 FEL Question #2
Sounds normal.
Keep in mind you are lifting that much weight with pallet forks. That will decrease the lifting capacity the further out you load is placed from the piviot pins.
/ Max28 FEL Question #3
Yeah, 800 lbs out on forks is probably exceeding the lift rating (which is normally at the pins). Loads on forks are much farther out, and can reduce the rating by as much as 50% depending on how far out.
/ Max28 FEL Question #4
Are you saying in the beginning the loader was lifting the 800 lb. load, but after that it would not lift the same load?
Yes it did also I had lifted a RR Tiller from my truck bed before without the forks and the last time I tried it would not pick it.
/ Max28 FEL Question #6
Take and lift a 25# weight close to your body, then stretch your arms straight out and lift the weight. Its the same effect as the loader is experiencing.
/ Max28 FEL Question #7
Your dealer can test the pressure to make sure the relief is not set too light, but as said above, a little leverage is a big deal.
/ Max28 FEL Question #8
Pallet forks extreme
Seriously considering a Max28XL as our little tractor, Just hope pound for pound it is as strong as our L39.
/ Max28 FEL Question #9
You will ba giving up a lot of capacity going from an l39 to a max28. But since the max is smaller and much lighter, pound for pound is probably on par.
Also keep in mind that the backhoe is a significant counterweight. You will need something equally significant on any other machine you choose.
/ Max28 FEL Question #10
What RPMs are you running?
/ Max28 FEL Question #12
That is a great example.
Yes that shed i lifted was all TT 2 x 8 in the floor Base, with 3/4 PT Plywood floor plus 2 x 12 box section where the forks inserted. it got really heavy with the 4 ft sliding glass door panel, T-11 siding and the interior paneled with masonite. The CG was far out from the piviot pins & as per my photo. Even with inner and outer wheel weights, etc bringing the tractor weight up to 8,000 lbs, the back wheels are not pushing on the ground too much. If the 12'4" x 8'8" shed had an asphalt roof, I could not have moved it. Loader was just about maxed out. Thats why I'm amazed the Max28 is rated at 1400 lbs at the pins. I wonder how much it could lift at 500mm in front of the pins?
Even if that number was 1,000 lbs, that a lot for the little Max 28.
i wish all amfactures would rate the tractors
3 pt- 24" behind lift point.
Loader: Lift at bucket edge at ground point.
Loader break out force at bucket edge at ground point. i.e. curling force
Lift at pins at full lift Height.
/ Max28 FEL Question #13
mike69440, I agree on what you are saying about standards for rating. I was thinking for the front bucket an amount that it can lift at the center of the bucket floor would be a reasonable number. A Max26/28 anywhere near max lift is a handful and works best if you have a backhoe on the back for ballast. It's a great stat for our marketing, but honestly if you want to lift more than 1,000 lbs very often, I'd recommend a larger frame machine like a 3016. I think a max lift rating ought to have a duty cycle attached. Like when you buy a welder, it may do 200 amps, but has a 40% duty cycle at 200 amps, and a 60% duty cycle at 150 amps and can run 100 amps all day long. That separates bragging rights from what the unit is really designed to do on a regular basis. The Max26/28 is great for that occasional load that would just be too heavy period for some of our competitors tractors, but I'd be cautious hauling heavy with it regularly.
/ Max28 FEL Question #14
I just want al small strong loader for the little but tough Jobs where I'd be making more of a mess than it would be worth using the L39 of even worse my excavator. my wife will throw rocks at me tearing up her yard.
We only have 4 Acres of pasture an an acre or so of Yard.
The small tractor is great for field work, Cleaning out the stalls, paddock, arena, garden work, york raking and scraping, draging trailers and spreaders, poop piles, and brush hogging.
1991 CAT 3406 Generator Set 400KVA/320KW, 480V 3-phase, 60Hz, Industrial Standby (A63689)
1991 CAT 3406...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
2021 Land Pride RCF2072 6ft. Rotary Brush Cutter Tractor Attachment (A61572)
2021 Land Pride...
6' ROTARY MOWER (A64280)
6' ROTARY MOWER...
1999 GMC C7500 Dump Truck (A61573)
1999 GMC C7500...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63689)
2006 Cadillac...
