   / Your last generator Maintenance Run #301
the older generac units auto exercised once a week for 15 minutes. the new units can be set to once a week, or every other week or once a month.
Alot of people (me included) thought 1 time a week was excessive. i program the units i set for once a month exercise.
Their liquid cooled units STILL require once a week exercise, but at lower speeds. Not sure why they wont let us program the liquid cooled for monthly tests.
   / Your last generator Maintenance Run #302
Once a month is a nice interval. This thread has helped me get closer to the every 3 months target I had, so I'm making progress :D !
A lot of equipment manufacturers won't spec oil intervals past one year, so that's a safe #.
Rgds, D.
I also run a 250KW generator at work 2X per month for 1 hour each time. One run with building load and one without load. Oil and all filters are changed 1X per year.
If mine was just a generator I'd probably do 3 mo. intervals.
3 months seems like a good target for my small portable generators. I can see where you'd want to spin up a welder more often though.
Rgds, D.
Interesting...... yes, once a week seems like a lot for a consumer level product.
On the newer systems, can you program the test-run duration ? Dead of winter here, I'm thinkng the engine won't fully warm up in 15 minutes, esp. if lightly loaded.
Sometimes seals perform better with frequent use (thinking water-pump seals).... best wild guess I've got.
Rgds, D.
How much fuel would you go through on that loaded run ?
Hopefully you've been allowed a bigger tank size than what ultrarunner is stuck with at the hospital.
Rgds, D.
   / Your last generator Maintenance Run #306
Rgds, D.
I work for a Hospital also (actually it's a one day surgery ctr. offsite from the main Hosp.). I do Bldg maint. and that's one of my jobs to run a diesel powered fire pump and the bldg. generator. We have a 1000 gallon outside tank that feeds two 50 gallon day tanks inside that supplies fuel to both. They don't use that much fuel. Fire pump runs 1/2 hr a week and Gen 2 hours a month. Once with and once without load. So 4 hours combined run per month uses about 20-30 gallons or so. Same tank also provides fuel for grounds skid steer and JD2305 used for cleaning sidewalks. The tank gets topped off once a year about 750 gallons.
1000 gal. sounds better, for a hospital.
Even half empty, that tank gives you about 3x the capacity ur has with a full tank (180 gal.).
Rgds, D.
   / Your last generator Maintenance Run #308
I forgot to mention our main campus (Hosp.) has 8 generators and a 10,000 gallon in ground fuel tank. They also just built a Co-Gen plant and produce their own power now and sell the excess back to the Grid. I've been stationed at the outside property the past 14 1/2 of my 30 years with them so haven't even seen the new plant yet.
Muitiple generators provisioned at 1,000 gal.+ per gen. Somebody was thinking.
Actually...... more like the envirocrats stayed out of the engineers way, and let them do their jobs.
Rgds, D.
   / Your last generator Maintenance Run #310
Me too...
When the 6 OR outpatient surgery unit went in the city/county had some very specific ideas that have only become more restrictive over time.
The 150 kW Prime rated Onan Cummins Turbo Diesel is limited to a 180 gallon tank... that's it and was hard to get approved... city simply was not approving anymore onsite fuel storage tanks. During California rolling blackouts it was touch and go keeping the ability to refuel viable.
Later, the Air Board issued new regulations effectively limiting exercise time to 30 minutes every other week... previously, we were running every week...
UNUSED CFG INDUSTRIAL H12R EXCAVATOR (A58375)
UNUSED CFG...
Snow Dogg 7.5' Snow Plow w/Bracket (A55272)
Snow Dogg 7.5'...
(2) TRACTOR WHEEL WEIGHTS (A58376)
(2) TRACTOR WHEEL...
PSI 8 Cylinder Power Unit (A57149)
PSI 8 Cylinder...
2016 FREIGHTLINER CASCADIA TANDEM AXL MID ROOF SLEEPER TRUCK (A59575)
2016 FREIGHTLINER...
1999 CAT 350E2 Haul Truck (A55272)
1999 CAT 350E2...
