adding top and tilt
/ adding top and tilt #1
runningbird
Gold Member
Gisela, AZ
yanmar 1110d ,fx28d
I'm looking for a bit of help. I have searched and found quite a bit of info but want to make sure I get this right.
I would like to add a top and tilt to my Yanmar FX28. I have a loader on it and will post pictures of my existing set up.
this is a picture of my loader valve, I'm thinking a power beyond could go in the top port which is not being used?
The hydraulic lines to the loader valve come from under the right foot rest. there is an on/off lever under the seat that controls the flow to those lines. I'll add some pictures here. This where those two lines come off.
this is where they end up under the right foot and connect to the loader lines.
I will add a couple pictures and questions at this point. I'm wondering if this plug might be a spot for a return line?
on the left side there are these to plugs or maybe not plugs, They are not marked like the lines on the right side. Is there a chance they could be pressure lines?
This is a picture from the front. this is the line from the pump entering the system. along with the 3pt drop speed knob.
I hope the picture will help someone help me. a question I have is, Is the best spot to get flow, out of the loader valve? Or would it be better if possible to get it somewhere else. What kind of valve or controller would work best?
Thanks for any help! I am at work and will check back when I have a chance.
/ adding top and tilt #4
How is your flow path? Point to point.
Is it from the pump to the loader then to the 3pt?
If the loader valve is feeding the 3pt now, then you can assume that the loader valve has a PB port.
Do you have six or seven hoses on the loader valve?
If you have PB coming to the 3pt now, then you can interrupt the flow at the 3pt for the remote valves for the T-N-T.
Flow path, I'm not sure, on my last picture that is the line from the hyd pump. On my second picture you can see that same line has well has the out and in lines that go to the loader valve. If I had to make a guess it would be pump-loader-3pt. if I did not have a loader the lever would be off, thus eliminating the two ports on the side that go under the rt foot and up to the loader.
There are six hoses on the loader valve. The top of the valve has a port which is not being used and I thought that would be a spot for the PB.
I'm sorry if I have not explained things well. and thanks for the help.
/ adding top and tilt #6
Find the port on the loader that feeds the 3pt and see if that port has a PB stamped by it.
The hyd may exit a hyd block and return to the hyd block and then to the 3pt.
Back track the hyd line going to the 3pt and see where it goes.
Who is the manufacturer of your loader valve?
This is how I think it is. I will check the loader valve and port when I get home.
these are the exit and return lines at the block. but I will check the loader when I'm home.
Thanks so much for the help.
so I checked the loader valve last night. the line on the bottom entering the valve is the in for the pressure. here is a picture of that point.
has you can see it is marked P i'm figuring that means the pressure connection. on the hydraulic block the same line is marked O for out I think.
after that I have ports that go to the loader cylinders. and at the top of the valve is the out port which goes back to the hydraulic block which is marked I for in I guess.
on top of the valve is another port which is not being used and it does not have a marking on it.
/ adding top and tilt #10
Logically speaking, a loader valve will have 7 ports.
In port = supply in
Tank port = cyl flow out
2 work ports for in and out for each cyl. total of 4
PB port with adapter = flow for the next valve.
It looks like someone got lazy and and connected the tank port back to the hyd block.
Normally the PB connection will feed the hyd block or the 3pt.
Most tank ports go to a tank line and is low pressure.
Most tank ports have a limited psi rating of about 500 psi.
Did you find the manufacturer of the valve?
You could remove the large hex plug and show a picture of the inside.
What you are looking for is a port that will accept something like this adapter to make the port a PB port.
/ adding top and tilt #11
I think that what you are calling an I is actually a T for (tank) and is the out going port. More than likely the top port is a power beyond port. You will probably need some sort of power beyond adapter to be able to make use of that port.
/ adding top and tilt #12
Looks like the valve is from Pace Manufacturing if you zoom up on the one picture. Valve looks very similar to a Brand Hydraulics joystick so the power beyond would be on the top.
/ adding top and tilt #13
JJ keeps asking, so here is the manufacturer of the valve, from your picture.
I am getting slow, got beat again! :laughing:
The I is on the tractor hyd block... there is an I for in, and a O for out. I think anyway.
on the Pace Valve the top port has a T in the picture I think you can see that, It goes to the Hyd block on the tractor that has the I above it. Most likely I did not explain myself well.
Thanks for Jumping in and help.
The Loader is a Koyker Loader, I was the lazy one who installed it. I followed there instructions. I really did not know there was another way to do it.
I will take that plug out when I get home and get a picture of what is inside there. Thanks for the picture of the PB adapter, I was not sure what that looked like.
I work till late Monday night but will get a Picture Tuesday morning.
Thanks everyone for your help!!!!
/ adding top and tilt #16
Since you are not experienced with hydraulics and I don't know anything about your tractor, do you know what a "Rear Remote" is?
and does your tractor have any?
/ adding top and tilt #18
In your third or last picture, you say that the straight pipe going into the 3pt is from the pump?
If so, that means that the flow goes to the front of the 3pt first and you have a lever to shut off or feed the loader. If that is true, then you could add a remote valve using the input to the 3pt and redirect the pump flow into the remote valve and then the PB from the remote could feed the present line to the 3pt. Remote valve tank line would go to tank.
The curved line from the large hex plug looks to be a tank line.
the straight metal is the 3pt drop rate valve, it rotates, it's a little hard to figure in the picture because I took the knob off to get the front panel off. the curved line is the Pressure line from the pump.
the curved line that you are referring too (I think) it is acually a rubber line vent that goes up to a small filter near the seat.
/ adding top and tilt #20
OK, I can go with that.
We need to figure out the feed line from the loader valve.
Can you verify that the tank line goes back to the hyd blk, and that is what the instructions called for.
Here is what you have in most loader configurations.
Pump to hyd blk, hyd blk to loader IN port, loader PB out to hyd blk, hyd blk to remote, remote PB to 3pt., then to tank.
All tank lines go to tank.
So if you want remote valves, all the valves should be in series and PB from each valves feeds the next valve.
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
Steel Wheelbarrow (A65640)
Steel Wheelbarrow...
2023 Wolverine DM-13-72W Mulcher, Skidsteer Mount (A62679)
2023 Wolverine...
2019 CAT 305E2 CR Mini Excavator (A62613)
2019 CAT 305E2 CR...
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
2020 CATERPILLAR 316FL EXCAVTOR (A65053)
2020 CATERPILLAR...
