Comparison Home Stand By Generators
/ Home Stand By Generators #1
warriordba
Hanover, PA
JD Sabre 2048
Hi Folks, any advice appreciated. Trying to decide by a Westinghouse WH7500E generator and a DuroMax XP10000EH. I have read really good reviews of teh Westinghouse but it is gasoline only although you can get an aftermarket propane adaptor. The Duromax can run on gasoline or propane. Amazon has good reviews on it as well. Westinghouse is supposedly US made, Duromax in China.
Consumer Reports has Rigid as best, Westinghouse midlevel and no review of Durmax.
Really I just want something reliable if we lose power for a day or so. Propane would be easier for family if I were away. I will be having the Interlock installed soon.
Thanks,
Glenn
/ Home Stand By Generators #2
I like the smaller units based on economical operation...
One of my friends has a whole house unit that works great if he can afford to fuel it...
I've got a little Winco 5Kw natural gas/propane with transfer switch... keeps all the essentials functional and with today's LED lights... my load has actually been dropping.
Also, I don't live in an area where A/C is common so no cooling load.
/ Home Stand By Generators #4
I work in the trade and I can't home build a genset, let alone an auto start, auto transfer standby generator for less than purchasing a commercial unit.
/ Home Stand By Generators #5
As you are on TRACTOR BY NET, have you considered a tractor PTO powered generator?
LINK TO T-B-N ARCHIVE: Search Results - PTO GENERATORS - TractorByNet.com
The problem with a tractor powered PTO generator is that most times the power is out for an extended period of time is due to a natural disaster, which is one of the times you may need your tractor to do storm cleanup. Unless you have a spare tractor, I'd recommend against it as a primary power source for a residence.
/ Home Stand By Generators #6
Personally, I would not purchase anything new with the Westinghouse name on it. As far as I can tell, it is not the same company that it once was, and is now more or less, just a name stamped on cheap products made by various suppliers. TVs, appliances, generators, etc..... take a look at the "Our History" page on their website.... it says nothing about being an American company.
Our History | Westinghouse
/ Home Stand By Generators #7
Just like Air Conditioners with the name Maytag, Tappan, Gibson, etc, These companies are long gone. The names are still used / bought by other companies
/ Home Stand By Generators #8
May as well skip the name brands and just go ahead with the 中国制造 brand.
/ Home Stand By Generators #9
We have an Eaton 20K whole house generator with an automatic transfer switch. Great piece of mind when the grid goes down. Heat, a/c, refrigerator, hot water, internet, the whole nine yards.
There is about a 30 second delay after the grid fails till the generator starts which is just enough time to cause all the digital clocks to need resetting.
Now, all this comfort comes with a fairly significant operating cost as the unit burns about three gallons of propane per hour. Every Saturday morning the unit exercises it self for about ten minutes. The exercise period is independent of the grid condition.
A friend recently installed a stand by unit that notifies his cell phone when the unit is running or if there is a fault with the unit or transfer switch. Now, that's cool beans technology.
Our unit has been on board four years and when the weather turns frightful you can sleep like a baby knowing your shower is hot and the beer is cold.. Highly recommend stand by powder
/ Home Stand By Generators #10
Get a whole house auto transfer switch gen set. It will not cost much more than pto set up. In bed at 3 in the morning when power goes out. Wake up hear gen set running , go back to sleep no problems. No hooking up, putting fuel in and flipping breakers.
Whole house gen sets is one of those things I will never be without.
/ Home Stand By Generators #11
It seems the consensus is to go whole house with the cost offset by the convenience it provides.
The frugal engineer side of me sees it could get expensive real fast if power is out for long.
I've got lights, gas furnace blower and a couple of outlets strategically located around the house on the auto transfer switch... so freezer, refrigerator, computer and a counter outlet in the kitchen are always ready to go.
My first home and one I still own is 1200 square feet and still served by it's original single 30 amp edison fuse for the main disconnect... having gas cooking, heating, hot water and dryer meant my electrical load remained low.
In my current 2400 square foot home... summer or winter I consistently average 12 kWh usage per day... must be the mile Bay Area weather.
/ Home Stand By Generators #12
Does a whole house unit run at high rpm all the time so that the high fuel consumption is SOP ?
/ Home Stand By Generators #13
Honda is as good as it gets when it comes to small engines and generators. Check also Yamaha. 5,000 watts should be enough for a whole house excluding A/C. Check Invertor-Generators by Honda and Yamaha, much more fuel efficient.
/ Home Stand By Generators #14
Yep, we have a similar setup with a Kohler 20kw on LP gas with an automatic transfer switch. Utility power goes off, generator power is own in 10 seconds. It runs everything in our all electric home including a 4-ton heat pump. It's been in service for nearly two years and has over 50 hours of running time on it.
Bill
/ Home Stand By Generators #15
So what if the rpms are high? That does not mean high fuel consumption or high wear. This is not the primary power genset at an Antarctica research station running 24/7. For a few hour a year who gives a rat's bum?
/ Home Stand By Generators #17
Diesel will only use additional fuel to maintain rpm when additional load is added. Unlike gas which requires a fixed fuel/air ratio & is using fuel based on rpm. While neither of those statements are completely true, diesel does a fair bit better on fuel usage under lesser loads.
/ Home Stand By Generators #18
I just recently installed a Generac 11KW propane generator with automatic transfer switch. This generator will run the whole house. These are the appliances that I run on propane, Bosch on demand tankless water heater, Sears propane stove. I heat with a Harman P43 pellet stove. All my lights have been changed to LED. So 11kw is more than enough but handy to have in case I decide to add more in the future. Best 6000.00 I ever spent. :thumbsup:
/ Home Stand By Generators #19
We've an Isuzu 12.5 kw diesel generator that does the whole house through a Generac panel that has 6 breakers on a sensing system that won't let them come on if not enough room on the generator. Had one long power outage during the last 2 years and wife was able to use the clothes dryer on one of those breakers. The upstairs heat pump is on another one of those sensing breakers.
The fuel usage on the Isuzu is about 0.2 gph. Used 2.5 gallons the first year and 5.0 gallons the 2nd year.
Ralph
/ Home Stand By Generators #20
A cheap gas generator will run 3600RPM constant. LOUD and uses lots of fuel. If anyone thinks they're going to run a house non-stop for several days with one of these things needs to be aware that they'll consume 1/2 to 1 gallon PER HOUR! So, if your power is out for three days, you're looking at 36-72 gallons of fuel, or, $90 to $210 just for gas! And read the oil change intervals on cheap gens, too. You'll be surprised how often its recommended to change the oil.
2012 Freightliner Cascadia (A63118)
2012 Freightliner...
CATERPILLAR T40D STRAIGHT MAST FORKLIFT (A62129)
CATERPILLAR T40D...
John Deere 7230 (A62180)
John Deere 7230...
2004 International 4300 Box Truck, VIN # 1HTMMAAMX4H667102 (A61165)
2004 International...
New 2025 NextGen 7x12 Utility Trailer (A61166)
New 2025 NextGen...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63118)
2012 MACK Tender...
