B2650 Exhaust residue on FEL hydraulic lines
/ B2650 Exhaust residue on FEL hydraulic lines #1
Porchfan
Oak Ridge, NC
2013 Kubota B2650 HSD, 2020 BX2380, JD LX-277 lawn tractor 2000
I notice I'm getting quite a bit of exhaust residue on the left side FEL hydraulic lines on my B 2650. I have about 50 hours on the tractor. The exhaust pipe is about 13 inches to the lines in a direct shot. I can't imagine this is good from a design perspective. The lines will definitely dry out faster. Any ideas on what I can do to minimize the exhaust and heat on the lines?
/ B2650 Exhaust residue on FEL hydraulic lines #2
I wouldn't worry about it. See it a lot with all kinds of different brands
/ B2650 Exhaust residue on FEL hydraulic lines #4
I have seen where some folks get pipe bent to 45 deg that is a bit larger than the exhaust pipe. Not too long or it can cause clearance problems. A couple of cuts in the new piece allow a clamp to snug down the pipe. I think about doing that every time I change from blade to blower....maybe next year.
Sent from my iPhone using TractorByNet
/ B2650 Exhaust residue on FEL hydraulic lines #5
I have the residue on my B3030. It's cheap camouflage.
/ B2650 Exhaust residue on FEL hydraulic lines #6
My B3200 does it too. It's on my list of things to do. I'm thinking one of chrome tailpipe tips that have a little curve in the end. Do they still make those?
/ B2650 Exhaust residue on FEL hydraulic lines #7
I have that as well. I've simply thought of just bending a small piece of sheet metal and clamping it to the pipe with a hose clamp.
/ B2650 Exhaust residue on FEL hydraulic lines #8
I'm not sure if it will work in your situation but I have taken a 3" cut off wheel and trimmed the end of the exhaust pipe at an angle to deflect the exhaust in a different direction.
/ B2650 Exhaust residue on FEL hydraulic lines #10
Here is what I did to correct the problem on my B3030. I went to a plumbing supply distributor and bought a copper fitting, can't remember the exact size but you won't find it at Home Depot or Lowes. I heated it up to expand it using pliers to hold it then slipped it over the Kubota pipe. When it cooled it fit super tight. I thought I might have to tack weld it but never had too. Been on for several years now and corrected the problem. I think the piece was about $10.00 +/-. I trimmed a little of the Kubota pipe so I could get the correct angle for the new copper piece. The pipe has turned quite dark so there was no need to repaint the exhaust. Hope this helps.
Giyi 2WD Mini QA Excavator Arm (A60463)
Giyi 2WD Mini QA...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2019 CATERPILLAR 420F2 IT BACKHOE (A59823)
2019 CATERPILLAR...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
