No turn over when key is turned?
/ No turn over when key is turned? #1
networker1
Glenville
L-48 Kubota
I have a year 2000 Kubota L-48 with only 1300 hours; front end loader and back hoe. AWESOME machine and no problems til recently! I turn the key to start with the clutch depressed and absolutely nothing. Battery is new!...all contacts on terminals cleaned. Can anybody HELP me solve this? THANKS! jimmy
/ No turn over when key is turned? #2
ok youve already checked and changed the battery.so it sounds like your starter has quit on you.so it needs tobe taken off took in and checked.
/ No turn over when key is turned? #3
Hold it before you go to all the work of removing the starter make sure it's the starter that's the problem. Is the pto shut off? Don't laugh I've done service calls for this. Does the tractor need to be in neutral or clutch pushed in before starting? Could be one of those switches. Could also be a disconnected wire somewhere. Check your fuses and the starter relay.
Ok so a quick way to check out the starter would be to access it and run a jumper wire from the battery post to the wire that engages the solenoid. If you try this please make sure the tractor is in neutral, key off and park brake on just for your own safety. :) If the starter turns the engine over the problem is elsewhere.
/ No turn over when key is turned? #4
Ditto. 445A
/ No turn over when key is turned? #5
Usually the solenoid goes before the starter, you should have some type of response from the solenoid whether it be a click or something. It is very rare they stop making noise one day. You may have noticed it previously during your recent start ups. This my cause concern that the solenoid was going. If you haven't experienced that i would start looking else ware. Good way to test is like previously stated jump the starter. That will test the unit itself, i would check the power from switch to starter. Remove the lead on the solenoid and put a test light on it. When you turn the key you should have power, if no power than there is a safety somewhere that has been tripped, or the ignition switch is gone. Do you have lights when you turn the key on? or maybe a faulty safety switch or pto on etc.
Also just for giggle check to make sure your battery has power, just in case you received a faulty battery.
/ No turn over when key is turned? #6
I don't know if a L-48 is similar to a L5030. On the L5030 there is a connector just a few inches from the hot terminal on the battery - mine was corroded and filled with dirt and exhibited the same symptoms you are having. There is also a fuse block near the battery than can be an issue.
/ No turn over when key is turned? #7
Chances are it is a switch.
/ No turn over when key is turned? #8
FWIW...
With the key turned to the start position...try wiggling the PTO/trans. levers...
If one of my PTO levers is not in the exact neutral position I get the same thing....
/ No turn over when key is turned? #9
Get a test light with a clip on the end and a light in the handle on the probe end. Harbor freight type item. Start by clamping to a good ground and follow the flow of electrical current. If it goes into the switch does it come out? Is it hot going into the solenoid? Just think it through until you find the problem.. My clutch pedal has a spot that has to be just right to crank over.
/ No turn over when key is turned? #10
You might want to check all safety switches (clutch, seat, PTO etc) as they will cancel starting.
Direct jumper to starter solenoid can confirm.
Another very common ailment is the started switch itself. The lubs tend to dry and cake up preventing contact.
A very simple cure is to liberally spray WD40 using the little tube into the key slot and wiggling the key left/right etc.
That action dissolves the dry lubricant and renews its efficiency to like new.
WD40 will not deter the switch life at all but simply renew it to like new.
/ No turn over when key is turned? #11
Check all your fuses.
/ No turn over when key is turned? #12
Learn how to troubleshoot, don't buy any part until you have checked it with a meter and know that it is bad,
Multimeter Tutorial
/ No turn over when key is turned? #13
Your PTO is turned on. You might have bumped the lever with your butt last time you jumped out. Been there, done that...almost tore the tractor apart. :)
/ No turn over when key is turned? #14
That sounds sorta kinky.
OK guys....I want to THANK all of you that had your suggestions and something in my gut said it is something simple and electrical as this tractor usually starts when you look at it hard enough.... and "just keeps on ticking". I started at the negative terminal off the battery and cleaned up the bolt that makes the contact to the main frame for the ground.....WALLLLLL-LAAHHHH....she fired right up! I'm back in action. If I was a tractor salesman...I could sell a L-48 with my set up of the Kubota front end loader 1150 and that gorilla of a back hoe....the 1100; amazing power and a smooth machine for a mid size tractor. It is a pleasure to run that thing while it sips fuel....and I hate climbing off it and shutting down...sometimes I just look for something to **** up! THANKS! to all of you....it is VERY much appreciated.....; great site for the average tractor guy! respectfully to all, ,jimmy
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
UNUSED WOLVERINE MCB-11-48W 48" HYD 4N1 BUCKET (A64281)
UNUSED WOLVERINE...
(2) UNUSED 17.5L-24 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
1985 Ford Ltl9000 Tender Truck (A63688)
1985 Ford Ltl9000...
UNUSED ATS POWER ATS-MIG-140 MIG WELDING MACHINE (A64281)
UNUSED ATS POWER...
2017 Ford F-150 Ext. Cab Pickup Truck (A61573)
2017 Ford F-150...
